Thread: high pitch turbo noise
  1. high pitch turbo noise
    Aug 2009
    wales
    hi, i have a 56 plate passat 2.0 tdi (140) and recently when the turbo comes in it makes a not normal high pitch noise,also when at high revs(3500-4000rpm) it cuts out completley and the coil light flashes so i have to knock the car off and restart it and its fine then untill i go up to those revs again.
    i have just joined the forum and cant wait to talk to u all
    cheers
    leights
  2. Re: high pitch turbo noise
    Norfolk
    It's going into limp mode, either because turbo boost pressure is too high or too low. You need a code read to find out. It's not unusual for the turbo vanes on that engine to jam and cause over boosting. The high pitch noise could be an air leak but it could be the turbo dying. Code read will point you in the right direction.
  3. Re: high pitch turbo noise
    Aug 2009
    leeds
    Exactly what mine did before the turbo hose split open. The noise was air escaping from a small hole when under high pressure. evenentually it gave way and split open. Cost about 400Euro at the time as it happenned half way through Germany!!
  1. humming chugging noise
    By ritter1 in forum Golf MK3 - 1993 - 1999
    Last Post: 16-05-2009, 11:28 AM
  2. Blown Turbo on AFN 1.9TDi engine?
    By justbretta in forum Archive posts
    Last Post: 18-12-2007, 04:56 PM
  3. Newbie - first post- looking to buy!
  4. Turbo Noise?
    By StuartMoore in forum Passat - Archive Topics
    Last Post: 02-05-2006, 09:37 PM
