Thread: 97 a4 1.8t aeb cuts out after starting intermittently
  1. 97 a4 1.8t aeb cuts out after starting intermittently
    Jul 2007
    hi and thanks for looking at my post.
    my 97 a4 1.8t sport with aeb engine is playing up.
    it can be a cold or warm start problem where it cranks over and fires up for a second or two then cuts out, it will do this anything from 2 to 10 times before it will keep running. when its running it runs fine.
    sometimes it starts perfectly and keeps running ok.
    i was told to change the cold start sensor, the blue one but it hasnt cured it.
    would vag com tell me the problem and does anybody know of somebody near me in shrewsbury, shropshire who has vag com.
    any help would be much appreciated, thanks, nick
  2. Re: 97 a4 1.8t aeb cuts out after starting intermittently
    Jan 2009
    towcester northants
    sounds like an immobilizer fault and suspect it will come up with key signal too small
    this is due to poor connections on the reader coil at ignition switch
    get diag test done on engine and immobilizer
  1. Pricing Set For Uk-bound Audi Tts Coupe And Roadster
    Last Post: 13-02-2008, 08:03 PM
  2. Tyres & Insurance
    By Sportingmac in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 17-01-2008, 05:59 PM
  3. A4 B6 1.8T coolant temp sensor location?
    By lwodrumm in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-12-2007, 05:41 PM
  4. Fast forward to spring with new A4 Cabriolet S line range
    Last Post: 02-02-2005, 09:26 PM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
