Thread: Blower only works on position 4
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 45
  1. Re: Blower only works on position 4
    #11
    Quote Originally Posted by eob View Post
    What age is you VW? Still in warranty? If your car is a B6 I'm still suprised at such an early failure.
    Are you asking me, eob?
    The age and mileage is in my signature, although it's now pushing 90,000 miles.
    06 Passat 2.0 TDi 140 SE Estate, Reflex Silver, 125,000 miles
  2. Re: Blower only works on position 4
    #12
    Norfolk
    Glovebox held in by seven bolts. Remove them and insert small screwdriver in slot near bottom to release. Pull out.
  3. Re: Blower only works on position 4
    #13
    toneil461 Guest
    Stuart, dead easy to replace the resistor. You dont have to remove the glovebox. Under the glovebox area (below dash) you will find a material type cover that his held by two screw type fixings., remove fixings using your fingers and remove cover. You'll find your pollen filter is located under this cover . look upwards and you'll see the resistor fitted in it's housing it'll have about 3 wires/connector going to it. The resistor slides out from the housing. Romove wires etc and refit new unit. The resistor DOES fail I have changed them before on Passats
    Hope this helps! Terry..
  4. Re: Blower only works on position 4
    #14
    Thanks, guys - I'll hopefully get to it next week, and if I can't get at it without removing the glovebox I'll revert to Martin's advice
  5. Re: Blower only works on position 4
    #15
    Sorted now - as Toneil says you just remove the cover under the glovebox and take it from there - you don't even need any tools, although you might need a lamp or torch.
    The resistor cost around Ł35 - if I'd known it was going to be so easy I might have tried to get one from a breakers and saved a couple of pounds, but it's done now.
    But thanks for all the help
  6. Re: Blower only works on position 4
    #16
    toneil461 Guest
    Well done Stuart! all ready now for Winter.
    Terry..
  7. Re: Blower only works on position 4
    #17
    Sep 2009
    Bristol UK
    Just had the same problem on my 2006 2.0TDI Passat. The resistor cost Ł30 ands a few pence from a main dealer. It is easy to get at and does not involve dismantling the glove box.
    Access is gained from the passenger footwell. Remove the 2 plastic screws holding up the foam cover (this also gives access to the pollen filter). You will see a black plastic electrical connector with four wires that goes into a white plastic holder. Squeeze the ends of the black plug to release the locks and pull out. At one end of the white socket is a lug that when squeezed will allow the socket to be slid to one side and removed. The white socket is the resistor unit. Replacement is the opposite of removal. Takes ten minutes tops.
    Unfortunately for me the new resistor pack lasted four days before the same fault appeared. Have contacted my dealer today by email and await a reply incase they supplied a faulty part or there is an underlying fault that caused it to blow so soon. Can't think what though.
    Pity there isn't a Haynes manual for this model yet. The previous model Passat is different from this one.
  8. Re: Blower only works on position 4
    #18
    Mar 2009
    Dundalk, Ireland.
    Hi all,
    My 2005 1.9TDI has just developed this fault.
    What is the correct name of this resistor and I'm guessing any VW dealership should stock it ?
    Many thanks.
  9. Re: Blower only works on position 4
    #19
    Norfolk
    VW call it a "series resistor" the part number should be 1K0 959 263A and cost approx Ł30.00.
  10. Re: Blower only works on position 4
    #20
    Mar 2009
    Dundalk, Ireland.
    Thanks for that Martin !
  1. Replies: 21
    Last Post: 16-07-2015, 03:07 PM
  2. Air conditioning / blower odd problem
    By dazza12 in forum Touran - Sharan - Caravelle
    Last Post: 21-07-2014, 08:41 PM
  3. Blower only works on fastest settings
    By tatham in forum Early Passat Forum - Pre 97
    Last Post: 01-03-2009, 02:13 AM
  4. blower is blowin with smoke when is set on heating position
    By simon121 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-11-2007, 11:29 PM
  5. Air Con / blower problem
    By stuart12 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-07-2006, 10:41 PM
