Thread: Brake warning light on startup
Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. Brake warning light on startup
    Nov 2008
    Audi A4 2002 1.8T - 72k
    Recently when I start the ignition I get the red brake warning light flash and beep at me three times on the centre display between the dials. At first i would only get it once out of every ten startups but now has become more often.
    It only happens on startup, never when driving, but unlike all the similar stories I have read I don't get any abs warning light at the same time. I don't seem to be leaking anything and the brakes feel fine.
    Any help welcome before I get mechanic to double check everything.
    Many thanks
  2. Re: Brake warning light on startup
    Southern County Softy
    20 Post(s)
    A8Tech done a write up on this....
    I think its a low voltage spike that sets it off.
    Check your battery.
    A4 2.5 tdi QS (mapped)
  3. Re: Brake warning light on startup
    Mar 2009
    Brighton
    Does this happen when you're parked on quite a heavy camber (to the left) by any chance?
    My brake warning comes on sometimes when the left side of the car is kerbside on a steep camber.
    I think it's probably down to the fluid falling away from the level sensor in the resovoir.
    Obviously checked all my levels and for leaks etc. and have seen no problem, so I don't worry about it.
    Embisix
    Current: 2010 A4 2.0TDI Quattro S line Executive Saloon (Sepang Blue Pearl)
    Previous: 2004 A4 Avant 1.9 TDI Quattro Sport (Atlas Grey)
    Previous: A string of (mainly) DOHC VTEC flavoured Hondas
  4. Re: Brake warning light on startup
    Nov 2008
    in reference to the battery, the car doesn't sound weak when starting but I'll get it checked.
    I do park on a slope, facing downhill, not left or right. Not too steep. I cant see any leaks but I'll keep checking the brake fluid levels over the next few days.
    The last two days, it has beeped as usual from startup and then again when I'm leaving my estate (about 30-60 secs later).
    I also noticed one time last week then I drove to the shop (2mins away) and it beeped as usual on startup and then again when I came out of the shop.
    Not too worried about it but just really annoying, as I said no problem with braking.
  5. Re: Brake warning light on startup
    Apr 2009
    I have the same issue, checked brake fluid res and was fine so disconnected the brake fluid level sensor and it stopped so thought ah need a new sensor but now its started again without that sensor refitted so mr AA man, another issue, has said it may be a faulty brake pad sensor that is intermittent. He reckons with the right VAGCOM software you would be able to prove this one either way so thats my next step, could be same for you..
  6. Re: Brake warning light on startup
    May 2007
    knee deep in clunge
    14 Post(s)
  7. Re: Brake warning light on startup
    20 Post(s)
    I looked for that thread and couldn't find it
  8. Re: Brake warning light on startup
    Aug 2007
    Newport, Wales
    7 Post(s)
    Take a look at this thread too.
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=56355
    Hull Audi retro-fitted a relay / wiring to my 3.0 which sorted the problem!
    Toff.
    [ My Cars: 2011 Caravelle SE TDI LWB | 2015 A1 1.4 TFSI | 2017 Jag F-Type R 5.0 V8 Supercharged ]
    [ Past Audis:
    A6 S-Line 3.0
    V6 TDI Qttr | A4 3.0 TDI Qttr S-Line | S6 4.2 Qttr | A4 2.5 V6 TDI Qttr Sport | A4 1.9 TDI Qttr S-Line | A4 SE 2.0 TFSI Quattro Avant | 2.0 TFSI Roadster ]
    [ Past VWs: Mk1 GTI Cab | Mk3 2.0 Cab |
    Mk3 VR6 | Mk4 R32 | Mk4 V6 MoFo | Mk4 Golf 1.9 TDI| Mk4 Supercharged 2.0 6-speed | VW Touran 2.0 TDI DSG ]
  9. Re: Brake warning light on startup
    May 2007
    knee deep in clunge
    14 Post(s)
    I forgot about that one,too many posts lol
  10. Re: Brake warning light on startup
    Nov 2008
    Many thanks all, that last link looks to be the problem. A bit short on cash at the moment so will have to scrap some together and get down to Audi. Think I'll ring around as the first garage I rang didn't have a clue so will try and get someone who has at least heard of the problem.
    Again many thanks, and will report back when I finally get it sorted.
    I'll try that check button test first.
  1. Question Fog lights install
    By deadly4u2nv in forum Golf MK5 - 2004 - 2009
    Last Post: 26-11-2014, 12:59 PM
  2. Which HID kit?
    By linners in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-04-2008, 07:36 PM
  3. Brake Pad Warning Light 54 Reg Passat Estate
    By alflavor in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-04-2007, 02:52 PM
  4. DIS Brake Fluid Warning with ABS warning light
    By radar1022 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-04-2007, 10:42 AM
