Thread: Golf VR6 - Coil Pack - Intermittent Fault
  1. Golf VR6 - Coil Pack - Intermittent Fault
    Jul 2009
    United Kingdom
    Hi
    I changed the coil pack on my VR6 back in January. Plug leads were changed a few months ago as well. Car has developed a fault on cylinder 1. Misfire. When its happening I can pull off the plug lead at the coil pack end and there is no spark. All other cylinders are fine. Trouble is - the problem comes and goes. I'll drive the car on a journey, with the misfire. Next time I start it up - its gone. When its gone, there is a good spark when I pull of the lead on the coil pack end.
    What's happening? My presumption is that the coil pack is failing - but intermittently. Is that possible?
    As the plugs hadn't been changed in a while, I changed them today for a new set of NGK platinums. Car is running really smoothly now on them. Thought maybe it had cured the misfire. But no - it appeared again. Pulled of the plug - no spark. But then as I was fiddling, it sparked. And started to run smooth again.
    It all points to the coil pack surely? I've bought a replacement from GSF where I got the other one. However I'm reluctant to change it over and send the other one off under warranty as if the fault is intermittent, then it may appear fine when they test it. And I will lose my money.
    Any thoughts?
    Paul
  2. Re: Golf VR6 - Coil Pack - Intermittent Fault
    May 2009
    rhodesia, nottinghamshire
    Hi mate, change coil pack or have a diagnostic..... whereabouts are you/
  1. Replies: 0
    Last Post: 15-08-2009, 07:48 PM
  2. 2.0 8v Golf Cutting out and wont restart
    By bnor-cupra in forum Golf MK3 - 1993 - 1999
    Last Post: 07-03-2008, 08:03 PM
  3. Vag Results , Anyone want to quote me and repair?
    By pete2vinal in forum Golf MK4 - 1999 - 2004
    Last Post: 13-02-2008, 04:35 PM
  4. Golf MK3 TDI; VR6 rear axle swap
    By tornadored7 in forum Golf MK3 - 1993 - 1999
    Last Post: 30-08-2007, 08:58 PM
  5. 24 MILLIONTH GOLF ROLLS OFF LINE - EXPANDED UK GOLF RANGE
    Last Post: 19-11-2005, 05:57 PM
