Thread: 2.oT Engine to replace 2.0 FSI engine
Hybrid View
  1. 2.oT Engine to replace 2.0 FSI engine
    Jan 2009
    Hi, broke a timing belt on my 2005 2.0 FSI . Removed the head and found about 10 of the rockers damaged as well as 10 valves bent. Need to take to engineering shop to have all checked out as well as cams. Thinking of replacing with 2nd hand engine from Japan. Would I be able to replace with GTI engine, and if so, what additional work / costs would be required to do so?
  2. Re: 2.oT Engine to replace 2.0 FSI engine
    Mansfield, UK
    You'd need the engine, wiring loom, ECU, matching instrument cluster and matching key. Some older instrument clusters and keys I can get around but I can't defeat the immobiliser on that ECU yet.
    Not sure of the engine mounting points or gearbox will be a direct fit.
  3. Re: 2.oT Engine to replace 2.0 FSI engine
    Jan 2009
    Quote Originally Posted by rplamp View Post
    Thanks - I thought the 2.0 FSI and GTI motor (Golf 5) motor were essentially the same, except for the turbo.
  1. World Debut For The All New Audi A3 Cabriolet
  2. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
  3. ADVANCED NEW FOUR-CYLINDER PIEZO TDI ENGINE
    Last Post: 17-05-2006, 08:14 PM
  4. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
