Thread: Manifold Pressure Sensor
  1. Manifold Pressure Sensor
    Dec 2008
    Could someone tell me how to find this on my passat, Manifold Pressure Sensor . Has come up on vag com and is i belive in limp mode. Loss of power.Problem seems to come and go.
  2. Re: Manifold Pressure Sensor
    Oct 2007
    What is the engine code?
  3. Re: Manifold Pressure Sensor
    Dec 2008
    Hi
    Have found said sensor removed and cleaned and the car seems fine been for a drive and no limp mode vag com has shown no faults with this sensor.I did notice a lot of oil on the sensor and if you look in the pipe you can see oil, How does this get there ? I would think now that i have to clean the pipes out ??
  4. Re: Manifold Pressure Sensor
    Oct 2007
    The oil in the pipe, to a certain extent is normal,it comes from the turbo,nothing to worry about.
  1. Fault 00575 - Manifold Pressure Sensor
    By BadgerBoy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-09-2014, 07:12 AM
  2. ABS Sensor: ABSolute pain!
    By tornadored7 in forum Golf MK4 - 1999 - 2004
    Last Post: 12-11-2009, 04:04 PM
  3. "How To" The FAQ & How To Thread
    By Ben in forum General
  4. Cruise Control cutting out
    By muleof1999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2007, 08:26 PM
  5. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
