Thread: alarm
Results 1 to 10 of 11
  1. alarm
    Jun 2008
    i have the dreaded swimming pool in the rear passenger side of my passat estate i have tried everything to find where water is coming from now everytime i lock the car within a few mins the alarm is going off anyone an idea wat the problem is cheers
    mark
  2. Re: alarm
    Norfolk
    Alarm works via ccm under passenger carpet. Check how wet that is and check the wiring too it. You will have to carefully unwrap the wires to examine them. They corrode especially at joints. After that you are looking for trigger points which include all doors, boot and bonnet. Have fun
  3. Re: alarm
    The alarm failure is caused by the water ingress through the pollen filter.
    Fix the water issue, remove and dry out the carpet and the ecu and bobs yer auntie the alarm will be fine - well mine was after doing all that...
    My ECU had some water in it (couple of tea spoons) but as I park backwards down a hill the majority of the water ran past the ECU.
    Best of luck with the fix. The guy who put this (http://www.weirdlittlebiscuit.com/passat/leak/ ) together is , in my book, a GOD!
    Pay particular attention to unblocking the drain holes under the battery and the servo. I DID clear both and 1 year on they blocked again and flooded the off side - I'll be checking every 6 months from now on. I now need to find out how to remove the sill trim and the drivers seat so I can lift and dry out the carpet - I hate VW and MY Passat!
    Best of luck
  4. Re: alarm
    Jun 2008
    cheers for the replys have tried to fix leak with a full tube of silicone and have dried carpets out as best as i can so hope it works
  5. Re: alarm
    Jun 2008
    the water is not coming in via pollen filter i dried carpet out and there has been no rain for a few days and i have had to dry carpet out a few more times so its not rain water im not losing anything from collant bottle i let the wiper bottle run dry incase the pipe was split but water still coming from somewhere anymore ideas please
  6. Re: alarm
    Southern County Softy
    20 Post(s)
    Could be a blocked aircon drain pipe.
    A4 2.5 tdi QS (mapped)
  7. Re: alarm
    Jun 2008
    where would i find that ?
  8. Re: alarm
    20 Post(s)
    I'm not too sure but I think it should vent under the car around the pax footwell area.
  9. Re: alarm
    Jun 2008
    FOUND THE LEAK pulled the carpet back and removed the silver box with wires goin into it and there was a pipe which i think might of been aircon pipe the grommet that it is supposed to sit in was twisted and the pipe was pointing to the pass. floor instead of through the grommet so took grommet out and put it back into shape and sealed it with half a tube of silicone so fingers crossed thats it sorted cheers for all your help
  10. Re: alarm
    Quote Originally Posted by mark78 View Post
    Consider the weather, have you had the aircon on that much? did you have the battery out and clear the drain valve below it? The plenum chamber flood can occur without having to go through the pollen filter, it can pass through the grommet sealing the air con pipes (this is well below the pollen filter). Fingers crossed is superstion, facts are needed!
  1. Please Help Alarm failure on passat 2001 2ltr
    By ST.Alban in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-07-2009, 08:18 PM
  2. Please Help Factory Alarm stopped working
    By avata_jo in forum Golf MK2 - 1984 - 1992
    Last Post: 21-07-2009, 07:01 AM
  3. Interesting information about the A4 Cabriolet Alarm
    By grahamnice in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 20-05-2009, 06:39 PM
  4. alarm triggered with driver door
    By Steve-R in forum VCDS - General Questions
    Last Post: 05-05-2008, 07:31 PM
  5. A4 - B6 alarm problem
    By xenon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-12-2007, 05:00 PM
