Thread: Rear Washer Leak
Results 1 to 8 of 8
  1. Rear Washer Leak
    Jul 2008
    I have an 05 A4 Avant which is leaking water from the top right hand corner of the tailgate when operating the rear washer. Water still comes out of the nozzles albeit at a pathetic pressure and continues to come out for a while afterwards. Cleaned out nozzles with no improvement.
    Any help would be appreciated as loathe to take it into Audi garage for what could be a simple solution.
  2. Re: Rear Washer Leak
    Nov 2008
    Beverley East Yorkshire
    Look behind the trim panel you will find the washer pipe has come apart at the union take it apart completly dry it off and glue it back together with some superb glue.
    Unauthorised commercial link removed as per forum rules
  3. Re: Rear Washer Leak
    Jul 2008
    Thks size12. Is trim panel easy to remove?
  4. Re: Rear Washer Leak
    Nov 2008
    Not a bad job if your used to removing plastic trims, they are straight forward just go slowly and dont over stress or break any of the lugs off.
  5. Re: Rear Washer Leak
    Jul 2008
    I had a go last night and got the lower panels off but then ran out of light so might have another go tonight.
    Thanks for your advice.
  6. Re: Rear Washer Leak
    Nov 2008
    no problem mate let us know how you get on.
  7. Re: Rear Washer Leak
    Jun 2009
    Darlington
    I have the same problem with Leon 05. took large bottom panel off but the problem wasn't there - was further back up towards the tailgate hinge and haven't tracked the problem down yet.
  8. Re: Rear Washer Leak
    Nov 2008
    Pull the head lining down at the back it might be on that connector there.
  1. Golf MK IV rear washer
    By amethyst in forum Golf MK4 - 1999 - 2004
    Last Post: 22-05-2009, 03:46 PM
  2. "How To" The FAQ & How To Thread
    By Ben in forum General
  3. A4 Avant Rear Windscreen wiper and washer problem
    By maudi25 in forum Archive posts
    Last Post: 18-01-2008, 10:45 PM
  4. How does the Quattro system work?
  5. Help please Re: Rear washer jet.
    By Big_E in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 14-06-2007, 12:29 PM
