Thread: Aaaaarh esp+engine light 1.6
Results 1 to 10 of 12
  1. Aaaaarh esp+engine light 1.6
    Mar 2009
    Hi guys,
    thought i'd the pros about a prob on the mrs Bug,
    popped over from the mk6 goof section so this is my first posting the new beetle threads. Anyway... to the bug mobile;
    I’ve just fitted a 3rd mass meter this week, so I guess it’s something else lol. The car revs really erratically at the lights and from cold, seems to be drinking allot of fuel, 300miles to a tank my Honda (yes I know) 2.3 auto accord does 364miles).
    I have a basic diag machine codes are;
    Engine
    17549
    16486
    16556
    Abs
    01314
    I’ve been told to check pipes for splits...... but I would know which pipes to check, any pointers
    Just nope it’s not both lambda or the car
  2. Re: Aaaaarh esp+engine light 1.6
    131 Post(s)
    1976 Post(s)
    Which year and engine code?
  3. Re: Aaaaarh esp+engine light 1.6
    Mar 2009
    its a x-plate 2000 iirc.... where can i find the engine code?
    thx for your reply and help
  4. Re: Aaaaarh esp+engine light 1.6
    131 Post(s)
    1976 Post(s)
    I don’t do text speak, I had to Google iirc to know what it was an acronym for…
    PM me your reg number and I will tell you the engine code.
  5. Re: Aaaaarh esp+engine light 1.6
    Mar 2009
    sorry, thx for the reply i'll pm you now.
  6. Re: Aaaaarh esp+engine light 1.6
    131 Post(s)
    1976 Post(s)
    It is a 2001 model with a 102PS AYD code 1.6 16v engine.
  7. Re: Aaaaarh esp+engine light 1.6
    Mar 2009
    your a star, any ideas on whats giving the errors?
    thx once again
  8. Re: Aaaaarh esp+engine light 1.6
    131 Post(s)
    1976 Post(s)
    Not just now, bump this later to remind me when I get home.
  9. Re: Aaaaarh esp+engine light 1.6
    Mar 2009
    "bump"
  10. Re: Aaaaarh esp+engine light 1.6
    Jul 2009
    Oxfordshire
    As I'm on nights and bored I did some research. They seem to point towards a Mass Air Flow sensor fault. Is yours firmly connected and not contaminated.
    Check all pipework after the air filter housing for splits that would cause a vacuum leak in the inlet.
    If you check for faults as recommended in the information below and have no success it is likely to be the MAF itself. I would wait for Crasher to respond before spending any pennies !!
    Code 01314 can probably wait until the other codes are investigated and cleared.
    Regards, Ian
    17549/P1141/004417 - Load Calculation Cross Check: Implausible Value
    Possible Causes
    • Mass Air Flow Sensor (G70) OR Manifold Pressure Sensor (G71) faulty
    • Vacuum Lines faulty
    Possible Solutions
    • Check Mass Air Flow Sensor (G70) OR Manifold Pressure Sensor (G71)
    • Check Vacuum Lines
    • Check Engine Operating Conditions => Meas. Blocks
    16486/P0102/000258 - Mass Air Flow (MAF) (G70): Signal too Low
    Possible Symptoms
    • Probably no serious malfunctions
    • Loss of power
    Possible Causes
    • Wiring and/or connections (short circuit?)
    • Mass Air Flow (MAF) (G70) defective
    Possible Solutions
    • Check wiring and connections
    • Check / Replace Mass Air Flow (MAF) (G70)
    16556/P0172 - System Too Rich, Bank 1
    Possible Symptoms
    • Irregular behaviour
    Possible Causes
    • Fuel system
    • Excessive fuel pressure
    • Leaking or contaminated fuel injectors
    • Leaking fuel pressure regulator
    • Low fuel pressure or running out of fuel
    • Vapor recovery system
    • Air leaks after the MAF
    • Vacuum leaks
    • Improper seated engine oil dipstick
    • Stuck EGR valve
    • Oil overfill
    • Cam timing
    • Cylinder compression
    • Exhaust leaks before or near HO2Ss.
    Retrieved from "http://wiki.ross-tech.com/index.php/16556/P0172"
    01314 - Engine Control Module: No Communications
    Possible Causes
    • CAN-Databus Wiring/Connectors from/to Engine Control Module faulty
    • Fault(s) stored in Engine Control Module
    Possible Solutions
    • Check CAN-Databus Wiring/Connectors from/to Engine Control Module
    • Check Measuring Value Blocks (MVB)
      • Usually Measuring Value Blocks (MVB) 125+ show the current Communication Status
    01314 - Engine Control Module: Check DTC Memory
    Possible Causes
    Possible Solutions
    • Check Engine Control Module for Fault Codes
    Royal Air Force Aeromechanical Engineer
    New Beetle 2.0 2001 72k in Pistachio
  1. Which HID kit?
    By linners in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-04-2008, 07:36 PM
  2. engine judder / vibrations and esp light stays on
    By gusyah in forum Archive posts
    Last Post: 29-01-2008, 02:49 PM
  3. Help! Loss of power, ESP Light on and Engine Judder
    By Jase1000 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-01-2008, 08:32 AM
  4. Does your oil light go out before engine start?
    By Alas in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-03-2007, 10:04 PM
