Thread: Where are these sensors ??
Results 1 to 8 of 8
  1. Where are these sensors ??
    Jul 2009
    uk
    I've done a Vag test on my sons 1995 2.6 V6 A4 with Climate/Heater probs.
    The problem is that the blower motor runs at full speed although you can adjust the speed on the LCD control unit, but nothing changes with the blower actual speed.
    Also the vents cannot be controlled whether you want to blow up or down etc.
    The control unit was changed and no change with the blower speed, but the vents could be controlled, then the cold air-con would not work.
    If the LCD control unit is totally disconnected the blower still runs at full speed.???
    Having done the test, the errors listed are:-
    0604 Flap motor (G113 sensor)
    1297 Footwell vent temperature (G192 sensor)
    1296 Central vent temperature (G191 sensor)
    Anyone got Pics or know where these sensors are and how to test them.
  2. Re: Where are these sensors ??
    Jul 2009
    uk
    OK, Having read various topics on the Aircon control etc. and reading the Circuit dia. The High pressure switch on the compressor could be at fault where it also controls the blower, The Audi America pic shows it in front of the Rad, where its actually behind the L/H of bumper as you look at the front of the car.
    Having found the switch and disconnected. The fan still runs at high speed.
    To do the same with the low pressure switch, the Pic frorm Audi America shows it to be on L/H side of engine bay as you look at the engine near the bulkhead. Can't find it.
    Any clues ???
  3. Re: Where are these sensors ??
    Dec 2007
    Quote Originally Posted by audikid View Post
    Any clues ???
    think u have a faulty blower or cc panel the faults u listed dont control the blower they control the flaps that run the vents take glove box out ull find them
  4. Re: Where are these sensors ??
    Jul 2009
    uk
    Quote Originally Posted by bez101 View Post
    Thanks,
    I've looked at the vents and flaps behind the glovebox and central radio/CC panel as the codes are for, but cannot see any sensor for the Flap behind the blower the codes refer.
    Also as I've said, the Blower runs at full speed even with the CC panel not connected/fitted.
    thanks
    2010 A6 C6-Avant 2.7 TDi LeMans (FaceLift)
  5. Re: Where are these sensors ??
    Jul 2009
    uk
    Carrying on searching through the net for info to the problems of the blower blowing at full spped with or without the Climate Control fitted.
    It has been mentioned about the 'Fresh Air Blower Control Module'.
    Any clues where would this be fitted and whats its look like.
    thanks
  6. Re: Where are these sensors ??
    Dec 2007
    thanks
    i rekon the blower is at fault as the other faults dont control the blower ur lookin for the motors that control the flaps look again u will see them
  7. Re: Where are these sensors ??
    Jul 2009
    uk
    OK. Forget the sensors codes listed and the flap motors etc.
    How can the Fresh Air Blower Motor be at fault when its running at full speed with the CC fitted or not.
    Which why I am now looking for the Fresh Air Blower Control Module.
  8. Re: Where are these sensors ??
    Dec 2007
    thats what i said the codes are nothing to do with the blower so itd a fault at the blower side do u have access to vcds if its the control modual if will show a code for it iv got a b5 16 sat in the yard same prob second hand blower fitted workin fine now
  1. Replies: 10
    Last Post: 17-11-2015, 10:51 PM
  2. Question Parking Sensors - more questions
    By rwab in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 19-08-2010, 07:48 PM
  3. Replies: 1
    Last Post: 14-12-2009, 11:49 AM
  4. Installation of Parking Sensors in 06 Passat
    By mac500 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-10-2008, 05:37 PM
  5. Advice needed on fitting VW Park Sensors
    By mikecb1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-04-2008, 09:58 PM
