Thread: really confused mk3 gti 92 2e
  1. really confused mk3 gti 92 2e
    Jan 2009
    near thetford
    im really confused i own a mk3 golf gti, it started idleing really erratically couple months ago its doin my brain in!
    so heres what i done i cleaned the throttle, checked all hoses pipes still nothin! confused!
    so me and me m8 had a look again we decided after fiddlin a bit that wen u unplug the temp sender that it stops so of course thought solved it
    got meself down to local parts shop got a new one plugd it in! i even replaced the plug makin sure the wires were all correct (plug looked bit coroded on connections) took it for a little spin and nothin had changed!
    oh the disapoinment!!
    also noticed it seems to beover fueling majorly!
    can sum1 please help!!
  2. Re: really confused mk3 gti 92 2e
    7 Post(s)
    Did you clean the idle control valve ?
  3. Re: really confused mk3 gti 92 2e
    Jan 2009
    near thetford
    how do i do that? (sorry bit of a novice its all a learnin curve)
  4. Re: really confused mk3 gti 92 2e
    Jan 2009
    near thetford
    seemed to have found an issue that mite caused it the throttle position sensor!
  5. Re: really confused mk3 gti 92 2e
    2019 Post(s)
    Yes very common on the 2E.
  6. Re: really confused mk3 gti 92 2e
    Aug 2009
    Tirana, Albania
    Ouch mate!
    I am afraid you will have to check the whole wiring of the ignition cirquit. I have the same problem as you and I have double checked every item under hood except the ECU. I'm having this problem from two months now and yet nothing! I have swaped the idle control valve (in the body of the monoinjection or electric carb), manifold gasket, dissasembled and cleaned the carb, checked all vacuum hoses (swaped even the pipes that pressurise the fuel tank and their carbon filter also), changed the distributor, the high tension coil, spark plugs, O2 sensor, temperature sensor with the correct code, alternator and timing belts, engine timing checked also! The throttle positision sensor is fine as I can notice the gas lever (where the gas cable is hooked) repositioning when the key is turned on. Fuel pump sends a fountain of petrol when intake pipe is unhooked off the carb, hence pump is ok and the respective relay also.
    And yet nothing! I am really ***off !!! The idling is still erratic and in a minute the engine shuts off. If temp sensor is unpluged idling lasts longer (8-9 min) but the engine stars "coughing" badly and shuts off after that! The only things I know I have yet to check is the wiring, ECU and ECU relay. VAG diagnosis did not help at all. It keeps displaying error codes on the distributor. If any one knows a magic spell to fixing this, please share!
    Good luck man!
  7. Re: really confused mk3 gti 92 2e
    2019 Post(s)
    Is this a 2E engine?
  8. Re: really confused mk3 gti 92 2e
    Jan 2009
    near thetford
    k so rite this is the stupidest thing eva coz oh yes it came BACK!!
    the worse thing bout it
    it was the Damn lambda sensor and at nearly £50 quid jus for the part but now i feels like a new car i even dared takin it to a cruise!!
    would defo try changin this then reset all fault codes
    and as for the dizzy tried adjusting???
    before u go buy a new ecu try cleanin the connection u wouldnt beleive the crap they can get in em
    hope this helps
  9. Re: really confused mk3 gti 92 2e
    Aug 2009
    Tirana, Albania
    Hi crasher,
    Sincerely I do not know how to tell the engine type. The little label on the engine cover is completely unreadable. It is a 1.4L petrol of '93 in a 1H cabin. All my problems started after a serious crash from a young tester of a 2.8L MK4 VR6 that destroyed 6 other cars with mine beeing the first in the death row!!! I managed to rebuild (not by myself) all the cabin and replaced all the parts I have mentioned in a post above. Yesterday I consulted (free of charge) a petrol engines engineer with 30 years of experience and he suspects the timing of the engine is slightly not in synch with the distributor. That makes the engine loose rpm fast and cut out. So I will let him open the engine cover and match every piston positiion with the proper distributor hammer (or rotating arm) position. According to him, the electric spark is delayed more than the distributor tolerance can fix by hand rotation (advance or delay). This causes the blast to happen latter, when discharge valves open the petrol keeps burning out of the engine hence the bad smell of unburned petrol, low power and later engine cut off. I will post the result ASAP.
    Thanks!
  1. Replies: 8
    Last Post: 09-11-2009, 04:49 PM
  2. How To: Convert Mk5 Golf Front End to GTI, GT or Jetta
    By goofer101 in forum Golf MK5 - 2004 - 2009
    Last Post: 01-07-2009, 04:45 PM
  3. Volkswagen presents concepts of the Golf GTI and new Polo
    Last Post: 13-06-2009, 04:20 PM
  4. Volkswagen presents concepts of the Golf GTI and new Polo
    Last Post: 20-05-2009, 09:45 PM
  5. Replies: 0
    Last Post: 28-10-2006, 05:22 PM
