Thread: No Glow Plug light?
  1. No Glow Plug light?
    Aug 2009
    Leighton
    My ol' faithfull won't start after 6 years and 205000 breakdown free miles!!
    I've noticed that the glow plug light is not lighting up on start up.
    The fuses on top of the battery are fine, glow plugs are also fine but there is no power to the glow plug harness??
    I'm assuming that the glow plug relay is the culprit here though rarely failing?
    Any clues where this relay is, the replacement I got is no. 202 and there is no relay numbered 202 on the relay board under steering wheel?
    Please can you help me get my '98 110 GT Golf back on the frog!
    Many thanks for any glow plug light shed on the matter.
  2. Re: No Glow Plug light?
    103 is the glow plug relay,position 4 on the carrier,what is the engine code?
  3. Re: No Glow Plug light?
    Aug 2009
    Leighton
    It's an AHF engine.
    Cheers for you help Kenney.
  4. Re: No Glow Plug light?
    Aug 2009
    Leighton
    I was thinking very breifly, this glow plug relay 202 that I've ordered, any ideas if this is a superceded relay for the 103? or is for another model? Will it work, the seller on ebay recons it will work fine.
    I'll have to wait and see, will keep you posted.
  5. Re: No Glow Plug light?
    Could well be a replacement for 103, i don't know,but if you remove the contact on the temp sensor,see if the glow plugs then work
  1. Question Fog lights install
    By deadly4u2nv in forum Golf MK5 - 2004 - 2009
    Last Post: 26-11-2014, 12:59 PM
  2. "How To" change a rear light bulb on an A3
    By djgilson in forum Audi
    Last Post: 16-04-2010, 03:54 PM
  3. Foglights Retrofit - VW Jetta / Golf
    By RickT in forum Volkswagen
    Last Post: 27-06-2009, 06:06 PM
  4. transporter 2.5tdi 2003 glow plug light not staying on?
    By vanrental in forum The Commercial Range
    Last Post: 09-06-2009, 04:44 PM
  5. Flashing glow plug light on 03 Ibiza 130 TDI sport
    By Maitland_78 in forum Ibiza - Cordoba
    Last Post: 10-04-2008, 04:45 PM
