Thread: Special tool
  1. Special tool
    Apr 2009
    Cardiff
    Does anyone know where I can obtain a VW 'wedge pliers' - part number 3372? This is used to remove the plastic liner of the rear hatch.
  2. Re: Special tool
    you can use a plastic wedge
  3. Re: Special tool
    Apr 2009
    Cardiff
    I have already tried using a wedge and all I get is the steel clips tearing away from the plastic liner. I believe the tool compresses the steel clip to enable the assembly to remain intact on removal.
  4. Re: Special tool
    They are a stupid patent i know,but use the wedge,to make an opening and lift the clips with a screw driver,by twisting the driver under the clips
  5. Re: Special tool
    Apr 2009
    Cardiff
    OK. I'll give that a try.
  6. Re: Special tool
    Coventry
    i didn't use any special implements when i took mine off.
    i may have wedged a screw driver in to assist prising it.
  1. 3369 special tool
    By B5freaker in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-06-2009, 01:41 PM
  2. VAG-COM : Exhaust Gas Warning Lamp
    By mlakhi in forum VCDS - General Questions
    Last Post: 03-06-2009, 08:56 PM
  3. Front flexi hoses, special tool?
    By kurtis in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-10-2007, 09:56 AM
  4. AUDI S LINE SPORTS RANGE RAISES ITS GAME
    Last Post: 01-12-2005, 08:52 PM
