Thread: Door handle has become loose.
  1. Door handle has become loose.
    Hello, can any body help with this one?
    My drivers door handle outer cover has become loose, it rattles about and I cant see how it is clipped into place, there are two locating slots at the bottom but I cant see how to remove it without taking the whole lock out.
    Any ideas? Thanks Pete.
  2. Re: Door handle has become loose.
    Southern County Softy
    20 Post(s)
    A4 2.5 tdi QS (mapped)
  3. Re: Door handle has become loose.
    Thanks Kite,
    All done, easy when you know how, I can never seem to find the good posts when I search.
    Thanks again all, Pete.
  4. Re: Door handle has become loose.
    Mar 2007
    Hi there
    do you know if this is the same on a 2002 A6?
    Also how did you get the outer trim off, the body coloured part?
    Robin
  5. Re: Door handle has become loose.
    Aug 2007
    Newport, Wales
    7 Post(s)
    Quote Originally Posted by robinp View Post
    Hi there
    I imagine it would be the same on the A6 as I'm pretty sure they use similar handles, so they should be held on using a similar clip.
    When I fixed mine, I decided just to push the clip into place. Once the clip is back in place, the door handle will probably stay put for years to come, no need to add an adhesive (unless it quickly starts to work loose again).
    Al.
    [ My Cars: 2011 Caravelle SE TDI LWB | 2015 A1 1.4 TFSI | 2017 Jag F-Type R 5.0 V8 Supercharged ]
    [ Past Audis:
    A6 S-Line 3.0
    V6 TDI Qttr | A4 3.0 TDI Qttr S-Line | S6 4.2 Qttr | A4 2.5 V6 TDI Qttr Sport | A4 1.9 TDI Qttr S-Line | A4 SE 2.0 TFSI Quattro Avant | 2.0 TFSI Roadster ]
    [ Past VWs: Mk1 GTI Cab | Mk3 2.0 Cab |
    Mk3 VR6 | Mk4 R32 | Mk4 V6 MoFo | Mk4 Golf 1.9 TDI| Mk4 Supercharged 2.0 6-speed | VW Touran 2.0 TDI DSG ]
  1. Loose 8P Sportback Exterior Door Handle
    By tates1979 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 08-03-2010, 11:40 PM
  2. Indicator Stalk loose connection?
    By Riven in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-11-2009, 10:15 PM
  3. compressor air outlet loose
    By sayloday in forum Chat - Anything with wheels
    Last Post: 04-02-2008, 08:41 AM
  4. 1.4TSI 140PS Touran Loose Compressor Air Outlet
    By sayloday in forum Touran - Sharan - Caravelle
    Last Post: 31-01-2008, 03:19 PM
  5. loose intercooler pipe! please help!
    By y2mash in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-09-2007, 05:17 PM
