Thread: Central Locking Woes
Results 1 to 10 of 12
  1. Central Locking Woes
    Aug 2009
    Rushden, England
    Hi All,
    I've just bought a Bora 150 Sport, which I have to say is fantastic, but I have one issue with it; the Central locking isn't working as it should via the remote central locking.
    When I press the button, the drivers door unlocks (as it should), then I quickly press it again, and the other doors should then unlock too, but they don't.
    Any ideas?
  2. Re: Central Locking Woes
    Southern County Softy
    20 Post(s)
    don't do the second press so quick...
    A4 2.5 tdi QS (mapped)
  3. Re: Central Locking Woes
    Aug 2009
    Rushden, England
    I tried that, but still no joy.
    I even tried the putting one key in the ignition and turning it to ON, and then locking the driver door with the other key manually, and then pressing the remote to unlock, this is supposed to sound the horn. You're then supposed to wait 6 seconds and then press the unlock on the remote again. This is supposedly how to fix my issue, but it doesn't work.
    I guess I'm going to have to go to a VW main dealer at this rate.
  4. Re: Central Locking Woes
    Disconnect the battery for 15 mins and reconnect. This resets the ecu and may well fix this issue
  5. Re: Central Locking Woes
    Aug 2009
    Rushden, England
    Will that mean that I'll need a code for the radio on reconnection???
    Needless to say I don't have the code....well not knowingly.
  6. Re: Central Locking Woes
    Quote Originally Posted by Brizee View Post
    No you will not need a code
    Let us know how ya get on!
  7. Re: Central Locking Woes
    Aug 2009
    Rushden, England
    SUCCESS!!
    Disconnecting the battery to reset the ECU fixed the problem...wohoo!!
    I still don't understand how come the ECU got it's knickers in a twist in the first place, but I'm so glad to have it working correctly again...you really don't appreciate how much you rely on central locking until you don't have it!
    Many thanks to all of you for your help.
    Cheers,
    Brian
  8. Re: Central Locking Woes
    SUCCESS!!
    Cheers,
    Brian
    Its mad, the day I offered that solution to you , my own boot sensor packed up. And no disconnecting the batterey didnt work
    I now have to stop the car and open the boot with the key every time, so 80s !!! Other than minor little things like this the car has been rock solid
  9. Re: Central Locking Woes
    Aug 2009
    Rushden, England
    How odd that it should suddenly stop working, but then if you're luck is anything like mine...it's not surprising. These things are sent to try us.
    Is it going to be some dodgy wiring or has somebody else on here managed to suggest a solution?
  10. Re: Central Locking Woes
    Sep 2010
    Cambridge
    hello, was wondering if any1 has heard of the problem with the 2000 Bora where the car wont lock via the central locking. but it locks from inside with the button on the door.
    then from locked when ur inside the remote central locking will unlock with the key....
    when pressing lock i can see the little red light flash but nothing happens.
    please help - Thanks Gazzer
  1. B5 A4 Central Locking FAQ
    By ini in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-09-2015, 11:46 AM
  2. Problems connecting Remote Central Locking ...2004 Polo E
    By andy4976 in forum Polo - Derby - Lupo - Fox
    Last Post: 29-06-2009, 10:24 AM
  3. Central locking woes
    By basic147 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-01-2008, 05:42 PM
  4. Faulty central locking control unit
    By hawaiian Floyd in forum Passat - Archive Topics
    Last Post: 07-03-2007, 06:36 PM
  5. weird Golf central locking problem!
    By daft in forum Golf MK4 - 1999 - 2004
    Last Post: 21-02-2006, 04:49 PM
