Thread: Front caliper pin wont fully tighten - keeps turning and turning
Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
  1. Re: Front caliper pin wont fully tighten - keeps turning and turning
    #21
    Apr 2016
    London
    Thanks crahser! I bought the tool yesterday and fixed it today. Worked wonderfully! Now one of the rear caliper piston is stuck to the point that it bend the rewind tool plate. Time for a pint!
    Sent from my SGH-M919 using Tapatalk
  2. Re: Front caliper pin wont fully tighten - keeps turning and turning
    #22
    118 Post(s)
    1883 Post(s)
    Time for a new caliper! Insist on being supplied with a new TRW unit, don't be fobbed off with an exchange unit, VW say those calipers can't be repaired. The only thing we will fit is new TRW, the part number doesn't have an E at the end if it is new.
    0 2 0
  3. Re: Front caliper pin wont fully tighten - keeps turning and turning
    #23
    Jan 2009
    Hi, is this thread still open, and where in Nottingham is Crasher, as I live in Derby so would be local for me? Thanks
  4. Re: Front caliper pin wont fully tighten - keeps turning and turning
    #24
    118 Post(s)
    1883 Post(s)
  5. Re: Front caliper pin wont fully tighten - keeps turning and turning
    #25
    Jan 2009
    A good Derby lad. I could do with some help with my daughters Polo 6C, which has a caliper slide pin thread that appears to be worn. I have put new discs and pads on and found that 1 of the slide pins won't tighten up fully. The insert looks like the job. Crasher, are you willing to travel to Derby to fit me an insert?
  6. Re: Front caliper pin wont fully tighten - keeps turning and turning
    #26
    Jan 2009
    Hi Crasher, sorry but I didn't realise the you have your own repair workshop. I am new to asking for help and posting on forums, as I generally only look. I wasn't trying to get a freebie. I was thinking of getting everything stripped on the car ready for the insert to be drilled and fitted. Naturally all paid for. Possibly best to contact you at your place of work. Apologies if any offence, just looking for some assistance.
  1. Replies: 21
    Last Post: 16-07-2015, 03:07 PM
  2. Question should my car have brake pads wear indicator?
    By lucianus in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-05-2009, 12:19 PM
  3. Sat Nav Retro Fit Fog Light Switch Problem!!!!
    By Kevin Hay in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-03-2009, 08:15 PM
  4. Replies: 0
    Last Post: 01-08-2007, 08:28 PM
  5. How does the Quattro system work?
    By webchem in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 01-07-2007, 04:44 PM
