Thread: can i drive with only 3 cylinders
  1. can i drive with only 3 cylinders
    Jul 2009
    gloucester
    hi guys, had a problem with my car for couple of weeks now due to smashed spark plug going into cylinder head(thankyou F1 autos), now its ******* out with smoke from exhaust and is really not drivable, i disconnected the HT lead from cylinder #1 and smoking stopped and drives alot better than it did
    So should i be driving the car on 3 cylinders, i get a wierd smell when i pull up after driving it, i am planning on getting new engine next month, do you think its ok to drive for short journeys till then
  2. Re: can i drive with only 3 cylinders
    Fuel is still being injected into the cyl,on which you have removed the lead from.I would not advise to drive the vehicle,and if you absolutly must,then remove the connector on the fuel rail to the damage cyl
  3. Re: can i drive with only 3 cylinders
    Mansfield, UK
    Less than advisable!
  4. Re: can i drive with only 3 cylinders
    Jul 2009
    gloucester
    ok guys thanks for replys, will wait for new engine to turn up
  1. Refused a Test Drive!
    By waccoe in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 31-03-2008, 02:47 PM
  2. New HDD-Disk Managment -Drive size is displayed as less???
    Last Post: 14-12-2007, 08:45 PM
  3. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
  4. How does the Quattro system work?
  5. The New Tiguan - Acceptance Drive in Namibia
    Last Post: 05-06-2007, 08:52 PM
