Thread: Very urgent - turbo buzzing and oil warning light! Need help fast!
  1. Very urgent - turbo buzzing and oil warning light! Need help fast!
    Jul 2008
    Dublin, Ireland
    Hi all,
    I posted a thread about this problem a month ago but the response was poor so I need some good help this time. I have a 1.8T quattro, first of the B5 series. I have a buzzing sound in place of the turbo whistle for the last month, this only starts when the engine is up to temperature and stays there until I stop up and let the engine cool. The red oil light comes on the split second after the buzz and will continue to go off and on in time with the buzzing noise. I've replaced the oil sensors on the sump and oil filter housing but it's not making a difference to the light. Does anyone know if there's a problem with the turbo on these or can anyone throw some light on this? It has my head melted at this stage! Thanks in advance.
  2. Re: Very urgent - turbo buzzing and oil warning light! Need help fast!
    Jan 2009
    towcester northants
    check oil presure!
    if the oil pressure is low it could of damaged the turbo due to oil starvation
    the oil feed pipes block so it should be checked
  3. Re: Very urgent - turbo buzzing and oil warning light! Need help fast!
    Jul 2008
    Dublin, Ireland
    Thanks for getting back to me, much appreciated! The local mechanic I gave it to recently reckons the oil pressure is fine but I don't have the equipment to test this, is there a way of checking this or signs of what you are talking about? Should I remove the oil feed pipes and check for blocking? Is there a way of knowing if the turbo is damaged?
  4. Re: Very urgent - turbo buzzing and oil warning light! Need help fast!
    Jan 2009
    towcester northants
    you could remove oil feed pipe and check for blockage
    also you can check the turbo for excess play remove the intake pipe to the turbo and remove the exhaust downpipe so you can check the impellor to se if it has too much rock and movement also to check if it is seizing up
  5. Re: Very urgent - turbo buzzing and oil warning light! Need help fast!
    Jul 2008
    Dublin, Ireland
    Thanks for getting back to me, it's much appreciated, I'll tackle it later this week and see how I get on.
  1. Audi 1.8t Oil and Coolant problems
    By laughingcamel in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-09-2013, 11:05 AM
  2. 1.8t oil light
    By sebco in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-03-2008, 03:39 PM
