Thread: Vag-com fault 01366
  1. Vag-com fault 01366
    Tullamore, Ireland
    Hi All,
    Just ran VAG-COM on my A4 B6. I got the following fault code: 01366 - Ross-Tech says the following:
    01366 - Opened Due to Crash Signal
    Possible Causes
    • Output Test performed on Airbag Control Module (J234)
    • Vehicle involved in Accident
      • Airbag Control Module (J234) stored Crash Data
    • Wiring/Connectors from/to Airbag Control Module (J234) faulty
    Possible Solutions
    • Check/Clear Fault Codes
    • Check Wiring/Connectors from/to Airbag Control Module (J234)
    Retrieved from "http://wiki.ross-tech.com/index.php/01366"
    I installed DIS and cruise control a few months ago so I would have had the airbag out and the airbag harness disconnected. I'll check the connections and run VAG-COM again but I was wondering if anyone out there had gotten this fault before after installing DIS and/or cruise or for any other reason?
    Any info appreciated!!
  2. Re: Vag-com fault 01366
    132 Post(s)
    1980 Post(s)
    See that after output tests, clear it and don’t worry about it.
  3. Re: Vag-com fault 01366
    Tullamore, Ireland
    Thanks Crasher, it appropriate that you replied, crashing is exactly what I worried about, and if the airbag will deploy or not! I take it you have previous experience of this code??
  4. Re: Vag-com fault 01366
    132 Post(s)
    1980 Post(s)
    I have seen it a few times and generated it as well doing output test, the first time I generated it was a little unnerving but it cleared and no brown trousers!
    By the way, excellent Avatar.
  5. Re: Vag-com fault 01366
    Tullamore, Ireland
    Thanks Crasher, I'll check the airbig harness connections anyway, clear the fault and leave it at that. Cheers!
  1. Please Help Engine Oil Pressure light, No engine fault codes on VAG COM
    By dfilogik in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 04-06-2010, 08:28 PM
  2. Healp needed VAG com
    By Snooze1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-06-2009, 07:47 AM
  3. Replies: 6
    Last Post: 13-05-2009, 05:20 PM
  4. Check my scan
    By kite in forum VCDS - General Questions
    Last Post: 11-05-2009, 08:03 PM
  5. 05 Audi A4 2.0 TDI problems
    By Dent Reform in forum VCDS - General Questions
    Last Post: 12-05-2008, 09:18 PM
