Thread: Replacing Sound Insulation Foam?
  1. Question Replacing Sound Insulation Foam?
    Feb 2007
    Norwich
    I have been lying under my car quite alot lately (Avant 1.9TDI).
    This is mainly due to correcting problems after unwisely taking it to a garage last week, after which more things needed fixing than before I had it looked at (but thats another story that I dont want to think about at the moment!).
    After the engine under tray dropped off while driving (away from the garage) and the foam was all but destroyed, I wondered about replacing this, and the material around the axle tunnels, which has also disappeared over time.
    Though this foam is preformed and has audi part numbers on it, dealer says this is not available. I wonder what the best stuff to use as a replacement is, obviously it should be proof against heat and oil products.
    Anybody had a go at this and have the ideal solution?
    Cheers,
    Timk
    Dec 2006
    NE Fife
    Probably the best solution (as it would still use genuine parts) would be to buy a secondhand one from ebay. You should be able to identify a part number from your existing item.
    It would save a lot of trial and error...
    Hope that this helps,
    Bob
  1. i'm going to sound like a dork but....
    Last Post: 27-04-2008, 07:28 PM
  2. Bose sound system.
    By Dozz in forum Audi A4 - Archive Topics
    Last Post: 11-06-2007, 09:21 PM
  3. Clunking sound!!
    By Boraboy in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 27-10-2006, 05:32 PM
  4. cracking sound when braking
    By arena432 in forum Chat - Completely Off Topic
    Last Post: 14-07-2005, 05:19 PM
