Thread: car wont start now
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
  1. car wont start now
    Feb 2009
    Middlesbrough
    after mine died and wouldnt start i had it tows and diagnosed it was a fuel injection pump which are 600-700 for a recon pump or 1200 new from vw i got one off a car today with 40000miles on i seen it running before we taken the pump off it and fitted it timed it up correctly but it just wont fire any one got any ideas? i am going to try and tow it off in the morning see if it makes any difference :/ its not showing any faults up now on the diagnostics
    (its a 90bhp 1.9tdi)
    with out dissapointment you cant appreciate victory
  2. Re: car wont start now
    Pembrokeshire
    22 Post(s)
    possibly not the pump. does the glow plug light come on with the ignition?
  3. Re: car wont start now
    Check you have 12v to the stop solenoid on the pump when the ignition is on,also that the engine control relay(109 in the fuse box) is working as they suffer from dry joints inside on the soldering or just fail.
    If the car died and a different pump still isn't working it sounds electrical.Was the car running fine before it died.
  4. Re: car wont start now
    132 Post(s)
    1980 Post(s)
    Try giving it a gentle and carefully administered shot of Easy Start. Beware though, it is easy to destroy the engine with this ether.
  5. Re: car wont start now
    Feb 2009
    Middlesbrough
    yeh it was i was driving the car and it just stoped as if some one turned off the ignition off then i went back to it later and it started but died again and wouldnt since, i had the diagnostic computer pluged in and it said the fuel pump wasnt working so i fitted a new one out of a car with 40000miles on i seen the car running before i taken it off. i fitted it to mine timed it up and it just tried to start it but it wont start i have pulged the computer in and its showing no faults now, tried towing it off but that didnt work iether just smoke off the unburned fuel i have had the cambelt off twice to check the timing and all apears to be well! i am lost where to go now..
  6. Re: car wont start now
    Feb 2009
    Middlesbrough
    sorry yes the glow plug light comes on, it jus turns over and wont fire
  7. Re: car wont start now
    Pembrokeshire
    22 Post(s)
    ok, the glow plug light being on indicates the ecu control relay is probably not the fault.
  8. Re: car wont start now
    Check you have 12v to the stop solenoid and that it clicks when the ignition is tuned on,maybe bad wiring somewhere if it stopped and fired up again .Try a pernament feed from the battery to the solenoid
  9. Re: car wont start now
    Feb 2009
    Middlesbrough
    you can hear the solanoid clicking in the fuel pump when you turn the ignition on and off and all the lights go out as they should on the dash just wont fire :/
  10. Re: car wont start now
    Feb 2009
    Middlesbrough
    are the relays under the bonnet? maybe worth checking these tmorro i will try anything
  1. Replies: 58
    Last Post: 01-03-2011, 09:46 PM
  2. S4 Review...
    By 73kingstonroad in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-05-2009, 09:24 PM
  3. Please Help Central locking works fine but remote doesn't
    By john_richter in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-04-2009, 02:46 PM
  4. "How To" The FAQ & How To Thread
    By Ben in forum General
  5. Audi Ancestor Could Be Most Expensive Auctioned Car Ever
    Last Post: 04-02-2007, 07:12 PM
