Thread: Passat estate - rear ashtray
  1. Passat estate - rear ashtray
    gibo.drum Guest
    hi all
    not posted for awhile found and able to fix most problems using previous posts so thanks. have a question - recently bought a rear ashtray and it has a connector attached which i think is used to illuminate the thing when its open problem is there's nothing to connect it to, my old ashtray did'nt have this connector.
    any thoughts? the car is a passatt estate 02
    Aug 2006
    Devon, UK
    Presumably the replacement ashtray was from a car with a higher spec than yours, hence the lighting connector. Its very unlikely that VW will have wired in the connector on a car which was never going to need it. I'd just forget about it.
    Passat Sport Estate 2001 1.9 TDI PD
    100k miles
    gibo.drum Guest
    thanks for replying your right not worth bothering about
    cheers
    yaktrebor Guest
    My 53 plate Passat Estate has a 12V outlet above the rear ashtray, is the connector something to do with this?
    gibo.drum Guest
    had a look at my outlet could'nt see anything to connect it to but thanks for the reply
  1. passat tdi 130 estate
    By terryuk22 in forum Passat - Archive Topics
    Last Post: 27-12-2006, 01:49 PM
  2. New Passat estate
    By Mike_S in forum Passat - Archive Topics
    Last Post: 27-03-2006, 11:01 PM
  3. 130 SPORT ESTATE. Water in REAR LH light well!
    By EddyStone in forum Passat - Archive Topics
    Last Post: 19-03-2006, 06:32 PM
