Thread: Replacing side light????
  1. Replacing side light????
    Apr 2009
    Northampton
    Hi, I have a 2004 (53 plate) A6, my offside side light bulb has blown, I have tried to replace it but had to give up!
    I tried by removing the plastic housing behind the light unit and squeezing my hand in, I tried pulling and twisting the side light housing but it just turns?
    Can someone help, how do I change the bulb? Do I have to remove the whole light unit?????
    Any help would be appreciated
  2. Re: Replacing side light????
    Mar 2009
    You will have to remove the air duct and the cover which sit just behind it. You can then unclip the two spring clips to remove the lamp cover.
  3. Re: Replacing side light????
    Apr 2009
    Northampton
    Hi, thanks. This is a UK car so the side light I need to replace is the other side from the air intake. I have got as far as removing the plastic cover from the back of the light unit but the bulb holder just turns in its housing, I have tried pulling it and turning but it will not come out. I am sure there will be a technique but so far I have no idea!
  4. Re: Replacing side light????
    Mar 2009
    You are nearly there: In the manual it states: –
    Turn bulb holder -1- anti-clockwise and pull
    it out of headlight housing.
    – Pull side light bulb out of holder.
  1. Question should my car have brake pads wear indicator?
    By lucianus in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-05-2009, 12:19 PM
  2. "How To" The FAQ & How To Thread
    By Ben in forum General
  3. Should Footwell Light work with Reading Light?
    By deviseruk in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-03-2008, 11:55 PM
  4. Audi A4 Cabriolet Replacing Side Light Bulbs
    By nrahuf in forum Audi A4 - Archive Topics
    Last Post: 10-02-2007, 09:35 PM
  5. side light problems
    By goonda in forum Passat - Archive Topics
    Last Post: 21-01-2007, 06:14 PM
