Thread: windscreen jets!
  1. windscreen jets!
    Aug 2009
    Chatteris UK
    Help please!
    I have bought a 97P reg VR6 Sharan - fixed the drain holes as wife was driving in heavy rain and passenger got wet legs! but main prob is that the spray jets to the front wipers very intermittently working. I have checked the pipes back as far as I can and they seem clear. Any ideas please and in laymans terms please I am useless with cars but wanting to learn now!!
    Thanks for any help!
    Peter
  2. Re: windscreen jets!
    May 2009
    Leeds
    You say they are working intermittently - if they work fine sometimes and not at other times it makes me suspect the pump motor or possibly wiring/switch. If you try it with the ignition on and engine off (so it is quiet) you will be able to hear if the electric motor is spinning ok. If the motor always turns but the water flow is intermittent then I would suspect debris in the water reservoir - you could try filling it/flushing it with a hose pipe and let it overflow to remove any muck from the container and see if that helps.
    Good luck.
  1. Windscreen chips
    By jonbaker in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-04-2008, 10:40 PM
  2. Passat Windscreen wash jets
    By AlB in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-03-2008, 01:05 PM
  3. Heated Washer Jets for Windscreen
    By Polo Mint in forum Polo - Derby - Lupo - Fox
    Last Post: 21-02-2008, 05:12 PM
  4. B6 Windscreen spray jets on mk4 golf?
    By mobitune in forum Chat - Anything with wheels
    Last Post: 20-10-2007, 11:39 PM
  5. Heated windscreen washer jets?
    By Zub in forum Passat - Archive Topics
    Last Post: 02-03-2007, 04:55 PM
