Thread: OBD2 compliant
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. Re: OBD2 compliant
    Aug 2009
    United Kingdom
    Hi Martin
    I have only just bought the car from a very good dealer and I have used the scanner for all the checks and the car is all clear.
    I have only bought this for my own personal use so hopefully I won't need to use it very much but as it is a universal not just a Volkswagen if I need to use it on the wifes car or daughters I will let the forum know.
    Norman
  2. Re: OBD2 compliant
    Aug 2009
    United Kingdom
    Hi Guys
    Another scanner related question,in the hand book for the scanner it says turn ignition on but don't start the car.
    In my car hadbook it says once the glow plug light has gone out start the car immediatly am I going to cause any problems by not starting the car while I am using the scanner.
    Thanks again
    Norman
  3. Re: OBD2 compliant
    131 Post(s)
    1978 Post(s)
    I always scan with the engine running when it will, some codes will occur on certain cars with the engine not running and some functions (like certain basic setting) are not possible with the engine not running.
  4. Re: OBD2 compliant
    Aug 2009
    United Kingdom
    Hi Crasher
    Thanks for the information,just curios as to why car handbook says start the car immediatly.
  5. Re: OBD2 compliant
    131 Post(s)
    1978 Post(s)
    I have no idea!
  6. Re: OBD2 compliant
    Nov 2008
    Lincoln, UK
    Quote Originally Posted by Norman vwp View Post
    Hi Crasher
    Norman, 'cos in normal cold starting, when the glo plug light goes out they are at their hottest and likely to give you the best cold start. Leave it longer and they will cool down again. Not an issue if you are doing diagnosis, as you are not planning to start at the time anyway.
    63 Audi A3 1.4 TFSI Sport
    Gone: 10MY Freelander 2 TD4 HSE Auto, Stornaway Grey. 55 SEAT Alhambra SX 130TDi (Grandad's taxi/shed) Freelander 2 TD4 SE manual, Rimini Red. 07 Passat Est SE 2.0 TDI 140 DSG Blue Graphite
  7. Re: OBD2 compliant
    #17
    Aug 2009
    United Kingdom
    Thanks dunkley201
    I have a 2 year warrenty on this car but I did not want to do something silly that would cause a problem.
    Your help is much appreciated.
    Norman
  8. Re: OBD2 compliant
    #18
    Aug 2009
    United Kingdom
    Quote Originally Posted by martin1810 View Post
    That's great Norman, let us all know how you get on with it. A lot of people ask about suitable hand held diagnostic machines, your feedback would help them.
    Hi Martin
    Thought you would be interested.
    I tried the scanner on my brothers 2003 VW Passat 1.9 diesel and according to all the information I have collected it should not have worked because the diesel before 2004 was not suppossed to be compliant but it worked great,
    I also tried it on his son-in-laws 1998 Passat (petrol)and it worked on that as well in fact it picked up 3 B+ low voltage faults on his so for the money it appears to be a very good scanner.
    Norman
  1. Compatibility of vag with my obd2 lead?
    By mike ryan in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 29-07-2009, 09:15 PM
  2. door locks, obd2 and other random questions!
    By wackyracer in forum Golf MK4 - 1999 - 2004
    Last Post: 08-04-2008, 08:48 PM
  3. Help- can't find the OBD2 port on a POLO Mark IIIF (2000-02)
    By ardasaliah in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 09-06-2007, 03:03 PM
  4. owner's manual key fob synchronisation
    By dannymccluskey in forum Passat - Archive Topics
    Last Post: 28-11-2006, 12:41 PM
