Thread: Odd starting problem.Help!!
  1. Odd starting problem.Help!!
    May 2009
    scarborough
    First of all here's info about the car:
    1994 Vento 1.6 8v ABU engine code,single point injection.
    In a morning or after work (when car been stood a good few hours) it never starts 1st time.I have to try it twice then it'll fire on the third try,always.No mater how long I let it turn over during the first two tries it wont fire.Runs fine once going.If I turn it off and then restart it imediately it'll fire on first try.
    It's had new plugs,dizzy cap,rotor arm,coil pack,fuel pump relay.Battery in good condition.
    Help!!!! I just can't figure it out.Where should I look next? Fuel? Ignition?
  2. Re: Odd starting problem.Help!!
    temp sensor
  3. Re: Odd starting problem.Help!!
    May 2009
    scarborough
    Thanks Kenny.
    Is that coolant temp sensor or engine temp sensor?
    http://www.eurocarparts.com/ecp/c/Vo...9fc1cee1c307e5
    or
    http://www.eurocarparts.com/ecp/c/Vo...9ec7df774d3cf8
    Thanks for your help.
  4. Re: Odd starting problem.Help!!
    Part Number: 460440720,but to be honest for all they cost,i think you should get a genuine VAG sensor
  1. Odd starting problem.Any ideas??
    By revol in forum Golf MK3 - 1993 - 1999
    Last Post: 29-12-2009, 09:41 PM
  2. Question Intermittent starting problem
    By tw2 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2009, 03:40 PM
  3. Starting Problem
    By mmlan in forum Golf MK3 - 1993 - 1999
    Last Post: 07-04-2008, 11:15 PM
  4. Starting Problems
    By blergo in forum Golf MK3 - 1993 - 1999
    Last Post: 26-02-2008, 07:00 PM
  5. Starting mortor making funny noise !!!
    By ARCHER85 in forum Golf MK4 - 1999 - 2004
    Last Post: 22-10-2007, 10:40 PM
