Thread: Passat Boot Lid Mechanism issue.. it won't stay shut!!!
  1. Passat Boot Lid Mechanism issue.. it won't stay shut!!!
    Nottingham
    Hi guys,
    I've attached a picture to show the problem area.. hoping someone can investigate theirs or tell me what the problem is!
    I opened my boot one day (today) and it wouldn't lock shut for some reason, it just "bounced" when I closed it. I've removed the trim and found a part of the mechanism that just seems limp and not on a spring which is what i'd expect. Can someone tell me if it is suppose to be springed, and/or what the issue is?
    I was thinking of using a bit of tape, but that's stupid
    Thanks,
  2. Re: Passat Boot Lid Mechanism issue.. it won't stay shut!!!
    Norfolk
    It looks like it has latched shut whilst open. Try Putting a screwdriver in between the tongue and the bottom of the "u" and pull the latch up until it clicks into place. See what this does.
  3. Re: Passat Boot Lid Mechanism issue.. it won't stay shut!!!
    The lock is not in the locked positon Martin,i would say Max needs a new lock.
  4. Re: Passat Boot Lid Mechanism issue.. it won't stay shut!!!
    Norfolk
    Shows what I know....I thought it looked shut....Just ignore me.
  5. Re: Passat Boot Lid Mechanism issue.. it won't stay shut!!!
    Aug 2009
    Derry, Northern Ireland
    This happened to me a while back. I took the mechanism of the boot lid which enables you to slide the metal part out of the black plastic sleeve. I found that the small expansion spring which keeps the latch in the correct position was broken at one end. The spring is shaped like a hook at each end and it had snapped at one end. I was able to form a new hook shape with a pair of pointed pliers and get it fitted back into place and it seemed to do the trick. I hope this helps
  6. Re: Passat Boot Lid Mechanism issue.. it won't stay shut!!!
    Nottingham
    thanks Irishvw, i'll give that a try for sure!
    Is it just a matter of undoing the two bolts to take the mechanism off to see this, or will I have to follow the haynes manual to take it off a different way?
    Thanks again for all that looked too
  7. Smile Re: Passat Boot Lid Mechanism issue.. it won't stay shut!!!
    Jan 2010
    kingswinford uk
    just spotted this problem I too had with my 01 TDI Sport Passat boot lid. It would shut but not completely catch so you could pull it open without unlocking. Tried adjusting catch to no avail, removed trim, all bits seemed in one piece solenoid whirred so assumed ok. Whilst in my local garage with my old faithful Golf I asked about this and his tip was to clean all the muck on and around the barrel, also to open lid and put some 3 in one in and around the centre of lock, having the lid open makes it easier to squirt the oil in without it dribbling down the lid and bumper. Put key in and turn it several times to help lubricate. Guess what, it worked! this apparently happens because we use the remote so much the mechanics never really get fully moved and though the whirring was doing some movement it wasn't quite enough. I know this won't be the solution to all the boot lock problems but it will certainly be the cheapest fix, it was for me!
    Last edited by stewart27; 06-01-2010 at 01:38 AM. Reason: accidental smiley inserted
  1. Boot lid only opens manually
    By jonbaker in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-02-2008, 02:43 PM
  2. Passat Estate: can't open boot.
    By Steve E in forum Chat - Anything with wheels
    Last Post: 27-07-2007, 12:08 PM
  3. Electrical problems with boot lid and Roof container lid
    By cabri-ole in forum Audi A4 - Archive Topics
    Last Post: 14-02-2007, 07:51 PM
  4. boot warning sensor comes on the display when the boot is shut
    By merchantmr in forum Audi A4 - Archive Topics
    Last Post: 06-02-2007, 10:04 PM
  5. Passat boot issue - locked out help!
    By KingConker in forum Passat - Archive Topics
    Last Post: 06-02-2006, 11:00 AM
