Thread: Engine shake. Again.
Results 1 to 10 of 13
  1. Engine shake. Again.
    Aug 2008
    Somerset
    I know this has come up before, but there seems to be a huge range of possible reasons for shaky idle on the 130pd lump. Amongst the possibilities I've read:
    - injector issues
    - failing MAF / dodgy MAF connection
    - engine mount
    - dirty EGR valve
    - low oil level
    Mine has just (past couple of weeks) developed a bit of a rock and roll at idle when starting from cold, but it more or less goes away when the engine's properly warmed up. Except... if you let it idle for several minutes when it's warm, in which case it gradually starts rocking again.
    Switching the climate control on or off makes no difference; neither does depressing the clutch pedal (so not the DMF then).
    It's due for a service in a couple of days and I'll be asking them to take a look, but suggestions of possible causes (including anything I haven't thought of) are welcome!
  2. Re: Engine shake. Again.
    Jul 2008
    Bristol
    I aint no mechanic, but I should think it could be the engine mounts. I think they need to be changed every 40 or 50K miles.
    I had toi change both of the mounts on mine, and it cost me 260 pounds, inc labour, from a specialist.
    But then again I could be wrong! It could be something very minor.
  3. Re: Engine shake. Again.
    I have this issue at the moment. Engine shaking at tick over, 800 revs, if I bring it up to about 1100 the shake goes away pretty much. Car is driving fine otherwise. Mechanic is certain it is the dual mass flywheel. Getting the flywheel and whole clutch kit changed tomorrow. Hopefully will fix it. Will keep you posted.
  4. Re: Engine shake. Again.
    Jul 2008
    Bristol
    Quote Originally Posted by JohnyIre View Post
    How much is it costing you to get the flywheel changed?
  5. Re: Engine shake. Again.
    Oct 2006
    Could it be the glow plugs as these can give lumpy starts and idle when cold?
    A4 Avant 1.9 TDi160 for when the weather is on the damp side - Sold after 9yrs. Now A5 3.0TDI Q Sport Coupe (310bhp/480ft/lbs - Yamaha R6 for when its dry and want some 'High octane Petrol' fun.
  6. Re: Engine shake. Again.
    Jul 2008
    Bristol
    Quote Originally Posted by Dave Avant View Post
    I doubt it, cause when I changed my plugs it still use to stay above 800rpm, for couple of seconds.
  7. Re: Engine shake. Again.
    Quote Originally Posted by Zeb View Post
    I'm in Ireland so it'll be in euro's. Flywheel + clutch kit(clutch disk, release bearing and pressure plate) are about 800 euro + labour. Will probably know later tonight what dent my wallet will take.
  8. Re: Engine shake. Again.
    Jan 2008
    Mansfield, UK
    The engine mounts are solenoids on the B6 130TDi aren't they? I had a lumpy idle on mine and Audi diagnosed a full set of injectors at £2400+labour. I didn't pay it
  9. Re: Engine shake. Again.
    Aug 2008
    Somerset
    Thanks for all the suggestions
    Now for the bad news: my lumpy idle has been diagnosed as being the result of a dead no. 1 injector
    The damage: around £600
    The kicker: my warranty expired just 7 days ago (when the car was still, as far as I can recall, fine. Or at least, the idle wasn't bad enough that it was bothering me).
    Throw in the service it was due anyway plus new front discs and pads and I've got a couple of pints' worth change out of a grand...
    Ah, well. It's just not been my week!
  10. Re: Engine shake. Again.
    Got car back after getting flywheel done. Engine shake gone, happy days for me!
  1. Court Hearing - Information required...
    By motyourcar in forum Chat - Anything with wheels
    Last Post: 17-08-2011, 09:31 PM
  2. Engine shake when switch off aircon
    By tyberwan in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-11-2009, 01:04 AM
  3. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
  4. Newbie - first post- looking to buy!
    By woza in forum Golf MK4 - 1999 - 2004
    Last Post: 05-03-2007, 01:41 AM
