Thread: Abs Fault..... Please Help!!!
  1. Exclamation Abs Fault..... Please Help!!!
    Apr 2007
    hi all
    i have a 1999 bora 1.6, the abs seems to be cutting in when i brake, its not that i am braking too hard because it does it as i am rolling almost to a standstill. Sometimes the abs light comes on and sometimes it doesnt.
    i have taken it to two garages and each time they have changed the f/r/h wheel sensor as it was showing the code fault on their computer.
    it has not changed a thing and i have no spare cash to do anymore to it. my friend is technical minded but requires some advice before having a look. Can any of you advise me on what to try next.....????? thanks.
    Quote Originally Posted by sels bora View Post
    hi all
    i may be way off base, but if the sensor is showing a fault and you've replaced it twice (unsure why the garage would do this twice...) then i would be looking more towards the actual wiring for the sensor, i'm sure i have seen that the wiring can suffer from water ingress and wear.... may be an area to consider?
  1. running fault odd.
    By mr audi in forum Audi A3 - Archive Topics
    Last Post: 13-03-2007, 10:27 PM
  2. T Reg Passat - Electrical Fault, Remote Central Locking Fault
    By adriana in forum Passat - Archive Topics
    Last Post: 01-03-2007, 06:27 PM
  3. VW Sharan fault
    By barnr in forum Touran - Sharan - Caravelle
    Last Post: 22-02-2007, 06:15 PM
  4. ABS Fault
    By mygolfvr6 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 06-07-2006, 07:37 PM
  5. A4 ABS ECU FAULT
    By big phil in forum Archive posts
    Last Post: 13-02-2006, 08:36 PM
