Thread: GSM/Bluetooth kit connection to Blackberry Curve
  1. GSM/Bluetooth kit connection to Blackberry Curve
    1. Does anyone know whether a cradle is available for Blackberry Curve?
    2. As a back stop I use the BB bluetooth conns to car which works well for in/out calls but the Call History function does not synchronise so comes up with random garbage on the MMI screen. Does anyone know how to make the call history synch?
  2. Re: GSM/Bluetooth kit connection to Blackberry Curve
    Kj5cott Guest
    Hi, see my posting (below) which was posted surrounding the phone book transfer of contacts not syncing with the car. The same principle should apply to call logs so please try and let me know if you have any success.
    Gents, I have had the same problem in the past and have spent nealry a year trying to get an answer from Blackberry and Audi. Good news is I;ve got the solution.
    To ensure the contacts transfer to the phone book as displayed in the MMI screen do the following;
    1. With your audi turned on and connected via bluetooth, disconnect and delete the pairing.
    2. Switch your audi off ensuring the ignition is off too.
    3. On you blackberry look at your email screen and hit the menu button and and select "view folder"
    4. Scroll down and select "phone call logs"
    5. Whilst holding the shift key scroll down to select all entries then delete them
    6. Repeat step 4 & 5 but select "missed calls" instead of phone call logs
    7. Now repair the blackberry with your audi.
    8. Voila, the phone book will transfer.
    The rationale for this fix is that the Blackberry memory stores all calls in a seperate part of its memory. if you delete the call logs from the phone screen i.e. when you select re-dial, this does not delete the items from the main "hidden" memory. The Bluetooth function tries to push the contacts from the "hidden"memory but becomes blocked due to its size. If you have not cleared the "hidden" memory in this way before you can have up to 9 months of call data stored in it which is too much for the bluetooth to handle.
    Hope this helps, let me know how you get on and remember to clear the hidden memory every few months.
    Kevin
  1. HELP!!!pair blackberry vs wv premium bluetooth
    By ilradi in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-08-2010, 12:37 PM
  2. blackberry connection
    By david bedford in forum Touareg
    Last Post: 21-05-2009, 10:35 PM
  3. Please Help No Connection Between Blackberry 8310 and Passat
    By Rob-A in forum In Car Entertainment
    Last Post: 01-08-2008, 12:11 PM
  4. Blackberry bluetooth = poor reception
    By ajl1 in forum A8 - S8 - V8
    Last Post: 05-04-2008, 10:46 AM
  5. Blackberry bluetooth
    By fatramy in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 21-01-2008, 04:13 PM
