Thread: 1993 Audi 100 2.5TDI - Clutch Problem
Results 1 to 8 of 8
  1. 1993 Audi 100 2.5TDI - Clutch Problem
    Aug 2009
    Winchester
    new to the Forum
    I have a problem with my 100 2.5TDI estate which I have had from new
    The clutch pedal has flopped to the floor. The car has not been used for a year.
    If I pump it I get enough pressure to be able to get the car into gear when it is running and it drives fine, but the "biting point" is right at the bottom.
    It also return some life to the peddle and returns to the top of its travel
    Presumably the car has an hydraulic clutch system
    Is there a slave and a master cylinder system..or does it work off the brake master cylinder with a clutch slave.
    How do I get to it - I cannot see anything from the engine compartment and or from inside the car.
    There does not appear to be any leaks - what do you think the problem is - slave or master.
    I always though the car had a cable clutch
    Any advice really appreciated
    Bill
  2. Re: 1993 Audi 100 2.5TDI - Clutch Problem
    I think there is air in the system,50-50 chance it is either the master cyl or the slave cyl,always hard to decide.The clutch master cyl is on the pedal bracket,the slave cyl is on top of the gearbox.You could try bleeding it first
  3. Re: 1993 Audi 100 2.5TDI - Clutch Problem
    Aug 2009
    Winchester
    Thanks Kenny
    how do I get to the master cyl - from inside the car? - do I have to take all the dash off
    Presumably I will see the slave if I get under the car?
  4. Re: 1993 Audi 100 2.5TDI - Clutch Problem
    the pedal bracket is the part the clutch pedal and brake pedal are fitted to.the slave cyl,is accessed from the engine bay
  5. Re: 1993 Audi 100 2.5TDI - Clutch Problem
    Aug 2009
    Winchester
    Quote Originally Posted by kenney View Post
    All I see in the engine bay is the big servo with brake master cyl
    If I remove the plastic cover under the screen in the Engine bay.I do not see any clutch "gubbins" either
    Do you want me to post a photo so that you can indicate where I should look
    I am reasonably mechanically minded and have usually worked on my own cars - so I know what I am looking for
  6. Re: 1993 Audi 100 2.5TDI - Clutch Problem
    better i send you the info send your e-mail address
  7. Re: 1993 Audi 100 2.5TDI - Clutch Problem
    Aug 2009
    Winchester
    I have to have 5 posts
  8. Re: 1993 Audi 100 2.5TDI - Clutch Problem
    Aug 2009
    Winchester
    I have to have 5 post - now I should be able to send my email address
    Thanks - as I am in France and trying to sort the car out
  1. Replies: 1
    Last Post: 14-12-2009, 11:49 AM
  2. New audi s4 raises the benchmark for handling dynamics
    Last Post: 12-05-2009, 08:10 PM
  3. The new generation Audi A3
    Last Post: 28-04-2008, 07:04 PM
  4. a4 multitronic problem
    By a4god2ulot in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-09-2007, 02:52 PM
  5. Audi Cross Coupé quattro - The compact performance SUV
    Last Post: 21-04-2007, 05:41 PM
