Thread: "R"Reg 1997 Audi A4 B5 1.8 SE Petrol - Fuel Pump
  1. Question "R"Reg 1997 Audi A4 B5 1.8 SE Petrol - Fuel Pump
    Jul 2008
    Birkenhead - UK
    After recently breaking down in birmingham and taking over 8 hours to be rescued
    We traced the fault to be the fuel pump
    I recently replaced the fault original with an aftermarket BOSH fuel pump
    The car now starts and runs but is sometimes hesitant and lacks abit of power (same symptoms as we had when the fuel pump was on its way out)
    And sometimes the car wont start unless you turn the ignition on twice (Allowing the fuel pump to come on twice too)
    I suspect because the fuel pump is a cheaper aftermarket replacement that it might not be displacing the right amount of fuel
    I will be removing the pump (yet again) to change over the plastic mounting brackets as the original one is a little different
    But as a quick question just wanted to ask could there be anything else affecting the performance or slight start-up issue ?
    Many Thanks
  2. Re: "R"Reg 1997 Audi A4 B5 1.8 SE Petrol - Fuel Pump
    Jul 2008
    Birkenhead - UK
    Will be undertaking the task of removing the fuel pump (again) tomorrow and checking all fuel lines
    Could do with a quick reply
    Also the car on start-up tends to rattle for afew seconds ... am i right in saying the engine also has a chain ?
    (1.8 20 valve non turbo)
    Could the slight rattle be a tensioner worn / on its way out ??
    Any suggestions or replies would be greatfully recieved
  1. 1.9 PD TDI Oil Change with Pella
    By Col in forum General
    Last Post: 21-07-2009, 07:56 PM
  2. Ultra-economical audi a4 tdi gets the ‘e’ treatment
    Last Post: 11-07-2009, 08:11 PM
  3. A3 dashboard change & fuel efficiency
    By tlionhart in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 22-06-2009, 05:49 PM
  4. World Debut For The All New Audi A3 Cabriolet
  5. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
