Thread: 1998 Audi A4 Avant 1.8 non turbo
  1. 1998 Audi A4 Avant 1.8 non turbo
    Mark A4 Guest
    Just about to do an oil change. However I am a bit confused as to which is transmission fluid and which is oil? Without removing the sump guard there is a plug visible with a weird hexagonal shape hole and when I remove the sump guard there is a another plug with a regular bolt however it is sideways mounted?! Can anyone confirm (maybe with a pic?) where the sump plug is for the engine oil.
    Thanks amigos!
    Mar 2007
    you want the normal bolt on the side of the lower half of the sump to change the engine oil. the other one with a recess for a large allen(hex) key will be for the transmission oil.
    Mark A4 Guest
    Thanks for that! I used my common sense and realised that the one on the side had to be the engine oil and have now changed the oil and filter.
    As a side note does anyone know where I can get transmission fluid, how much it holds and how often it should be changed? Changing to 1st and reverse when the car is staionary is very "notchy" and hope a fluid change might help!
  1. Audi A6 Avant 1.9tdi 130pd turbo not working
    By barney2 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 02-03-2013, 12:04 AM
  2. Smoke comming through air vent audi a4 Avant 1998
    By JT73 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-02-2010, 11:50 PM
  3. Audi A4 turbo Sport 1998 advice
    By shaba in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-10-2007, 01:29 AM
  4. 1998 Audi Avant Central Locking Problem
    By Mike66 in forum VCDS - General Questions
    Last Post: 14-03-2007, 09:00 PM
  5. Passat 1998 1.9Tdi, Audi A3 1998 1.8
    By sia3 in forum New Member Introductions
    Last Post: 05-03-2007, 10:51 AM
