Thread: Glow plug fuse strip - Passat B4 1.9 TD
  1. Glow plug fuse strip - Passat B4 1.9 TD
    Aug 2009
    Rijeka, Croatia
    Does someone know where fuse strip for glow plug is located? I cant find it. It is 1.9 TD/55 KW passat from '96. It has glow plug relay number 104.
    Thanks in advance.
  2. Re: Glow plug fuse strip - Passat B4 1.9 TD
    Norfolk
    80 amp fuse. Plastic box, left side of engine compartment I think.
  3. Re: Glow plug fuse strip - Passat B4 1.9 TD
    Jul 2008
    I think the one you are looking for is located in a small plastic holder on the bulkhead at the rear of the engine compartment, if the cover is missing it usually gets corroded and then fails. If I remember rightly it is to the left of the coolant reservoir. Mine was always going so I kept a few spares in the ashtray. Hope this helps.
  4. Re: Glow plug fuse strip - Passat B4 1.9 TD
    131 Post(s)
    1979 Post(s)
    On top of the fuse box under the dash.
  5. Re: Glow plug fuse strip - Passat B4 1.9 TD
    Chipped2 Guest
    Left of plastic header tank. 50 amp fuse from VW. Fits under 2 lage screws. Should have cover but lid can break off. Fuse looks like thick grey lead foil. U-shaped. Keep a spare.
  6. Re: Glow plug fuse strip - Passat B4 1.9 TD
    131 Post(s)
    1979 Post(s)
    On the AAZ engin it is a red platsic large type 50 amp plug in fuse on top of the fuse box.
  1. MK3 Golf TDI Glow Plug starting issues
    By 27motorhead in forum Golf MK3 - 1993 - 1999
    Last Post: 01-10-2010, 12:02 AM
  2. Replies: 0
    Last Post: 15-01-2008, 09:05 PM
  3. Audi A3 (1999) TDi Glow Plug Problems
    By Dr Diesel in forum Archive posts
    Last Post: 23-12-2007, 02:48 PM
  4. 1997 A4 1.9 tdi glow plug flashing
    By hudson in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-12-2007, 05:34 PM
  5. Delay in glow plug coil light coming on.
    By VW driver in forum Chat - Anything with wheels
    Last Post: 12-10-2007, 10:57 AM
