Quote Originally Posted by alexcf View Post
Hi guys (and gals!),
My tyre pressure monitor went off today, so went down to the petrol station and pumped the tyres up... Got back in the car and the thing is still going off ... Drove around a bit, maybe about 10-15 minutes and it still was showing up.
Has anyone else got this feature and had this problem? Will it go away by itself or would it be worth booking into the garage?
My only concern is that from what I understand it gauges the pressure from the ABS!
Thanks in advance
Alex.
it gauges the pressure from a thing on the inside of the wheel get a vcds scan done see if u have fault codes i had it once on a 6 was the lil sender in the wheel
