Thread: does vag-com tell you what frequancey your remote is?
  1. does vag-com tell you what frequancey your remote is?
    Jul 2009
    sheffield uk
    hi just a quickie...... i have been having trouble getting me remote fob to work on my 1998 passat and am wondering if there is a way to find out weather i have the right remote for the car as it is the only onei got with the car?
    also the alarm horn does not sound when alarm goes off but the hazzards flash as they normally would.... are these problems connected? only fault codes in vag-com are inplausable signal to rear left door intermittant.... what ever that means?
    help very welcome
    thanks
    ian
  2. Re: does vag-com tell you what frequancey your remote is?
    Bradford
    If you prise the two halves of the remotw apart, it has the frequency listed there.
    Chances are yours will be a 433Hmhz fob. Mines a 1999 1.8 sat, and its 433Mhz. 434Mhz i think only really started coming in on the next model up...
  3. Re: does vag-com tell you what frequancey your remote is?
    Norfolk
    Black magic....If vag-com reports a fault at one of the doors you will have problems with central locking because the ccm will be unsure if the doors are locked or not. You could have a faulty rear door lock but check the wires to the back door where they go from the B post into the door. There is a connector somewhere there that can work loose.
  4. Re: does vag-com tell you what frequancey your remote is?
    Jul 2009
    sheffield uk
    yeah i checked the plugs , but did have to do some re-wiring to ccm as the wires had all fused together in footwell when i got car but tried different ccm's and still the same all doors do lock with key just remote will not, i cant seem to get it to programme what so ever, as for the alarm horn not working just wondered if all these problems might be connected in some way (hopefully something easy that im missing lol)
    thanks
    ian
  5. Re: does vag-com tell you what frequancey your remote is?
    Sep 2008
    hi there just to say that horn not sounding is unlikey to be related as this simply requires some minor changes made using vcds which will then enable the beep noise when alarm is armed.
  1. reprogramming spare key / fob
    By mikegally in forum Golf MK5 - 2004 - 2009
    Last Post: 22-07-2017, 10:48 PM
  2. "How To" The FAQ & How To Thread
    By Ben in forum General
  3. MK 4 Golf 2004 Remote Re-Sync Info Req
    By teapot in forum Golf MK4 - 1999 - 2004
    Last Post: 07-02-2008, 09:31 AM
  4. Are And Vag Com / Vag Tacho The Same
    By davecoz in forum VCDS - General Questions
    Last Post: 21-11-2007, 09:13 AM
