Thread: Brake pad recommendations
Results 1 to 10 of 10
  1. Brake pad recommendations
    Poole, Dorset
    My 3.0 quattro needs an oil change and front pad, should i go for the Green stuff Brake Pads, are they worth the money, do i need to change the discs as well if i go with the green stuff? OR save my money and buy a standard set from Euro/GSF.
    recommendations please
    Thanks.
    Audi A4 3.0 QST B6
    Mercedes 190e 2.6 w201
    Mercedes 190e 1.8 w201
  2. Re: Brake pad recommendations
    133 Post(s)
    1985 Post(s)
    I would suggest genuine discs and pads, they cost less than you think and last far longer. It is quite normal to have to replace discs and pads together these days, pads last so long that the discs are often worn too far to be able to last the life of another set of pads. Some aftermarket discs are fine such as corrosion coated Zimmerman (Dacromet or Geomet D coating) and pads from Textar are exceptionally good but don’t go by price alone, it is rarely the best way.
  3. Re: Brake pad recommendations
    Poole, Dorset
    ^^ Thanks, had a look today and discs are fine will look into
    Textar pads, so do you rate original pads or Textar over EBC greenstuff.
    Audi A4 3.0 QST B6
  4. Re: Brake pad recommendations
    133 Post(s)
    1985 Post(s)
    I haven’t used EBC that much, when I use performance pads they are usually Black Diamond Predator. Textar are OE VAG, often when you fit genuine pads they are stamped Textar on the back.
  5. Re: Brake pad recommendations
    Poole, Dorset
    Oh right thanks for your help, think im going to stick genuine parts.
    Audi A4 3.0 QST B6
  6. Re: Brake pad recommendations
    Mar 2007
    Lancashire
    If it's any help I put EBC discs and pads on my A4 2 years ago. Much happier and preferred to the OEM. Much more bite from cold and have warn superbly. I'm no heavy braker but like a nice bite when pushing the car. Times that I have there has been no fade. The greens can get a faint squeel from time to time, but, that's from pootling to work too much and need a good run on them.
    I upgraded the pads on my TT to redstuff and they were better than OEM too. Much more confident when under heavy braking. I push the TT much more as it's for weekend and the redstuff are super... zero noise.
    I wouldn't hesitate to replace either car with EBC again. Personally think they are worth the extra over OEM. I don't mod much, but brakes I have to have biting nice.
    A4 1.9TDI 160bhp Sport - 2001 (51)
    Re-map by more-bhp.
    TT 3.2 V6 DSG quattro 270BHP - 2003 (53)
  7. Re: Brake pad recommendations
    Oct 2006
    I've had a few inconsistences with EBC, but they are good. I've put a set of EBC on my bike and when hot and on the track I had to clench my thighs against the tank to stop myself going over the handlebars!!
    I had a set of redstuff on my coupe turbo and they lasted 40mins!!!!!!! Honestly, I think I got a duff set, you could feel the pedal sink as I was braking, they wore straight down to the backing plate. Had to drive from Bedfordshire to Manchester with no front pads, to late to get to Halfords! Using the handbrake on the motorway isn't pleasant!!!
    My brother uses Yellowstuff on his M coupe and swears by them.
    Textar are also very good, they are up there with the racing pads like Pagid and are factory fit sport pads. I rate the standard brakes on mine. I've had my discs go blue with no ill affects or fade!!
    EBC originally made pads for race bikes, but moved in to cars aswell. I used to have problems with greenstuff after a trackday, when I used the brakes on the road, they felt tired and hummed. The older V4 compound had copper in the pads to help dissapate the heat, but the copper melted onto the discs making them feel warped. But this is going back a bit when I used to go through about 4 sets a year doing trackdays. The more recent compounds are better.
    A4 Avant 1.9 TDi160 for when the weather is on the damp side - Sold after 9yrs. Now A5 3.0TDI Q Sport Coupe (310bhp/480ft/lbs - Yamaha R6 for when its dry and want some 'High octane Petrol' fun.
  8. Re: Brake pad recommendations
    Mar 2007
    Lancashire
    Quote Originally Posted by Dave Avant View Post
    I've had a few inconsistences with EBC, but they are good. I've put a set of EBC on my bike and when hot and on the track I had to clench my thighs against the tank to stop myself going over the handlebars!! .
    Followed by a trip to the pits for new underwear...
    People do say -ve things about them. You must have really hammered then on the track to have no pad left!!
    I doubt EBC are the best track pad but for general fast road use, or even standard driving they do the job for me. I read an article about a guy who put redstuff on his 3.2 TT and said the caliper paint melted and went brown before the pads gave out. I've had mine on 2 months and they are improving all the time.... no wonder I don't drive the TT enough.
    Re-map by more-bhp.
  9. Smile Re: Brake pad recommendations
    Hook, Hampshire.
    My original fit pads (Textar OEM) lasted 65,000 miles on my 2004 2.5 TDi Quattro Avant Auto. Discs show light wear, and will need changing when the pads are done again (probably 100,000 miles plus).
    Regards Bobcat.
  10. Re: Brake pad recommendations
    Oct 2006
    Quote Originally Posted by Bobcat View Post
    Regards Bobcat.
    I'd believe that mileage. I bought my car with 66K miles and had new discs and pads. Still got plenty left after 20K miles and I do like to use my brakes.
  1. Question Golf Mk4 GT TDI Rear Wheel Bearing
    By tommi in forum Golf MK4 - 1999 - 2004
    Last Post: 25-05-2009, 08:21 PM
  2. Wishbone Front / Rear Axle Bush which brand
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 23-05-2009, 12:27 AM
  3. Brake Pad recommendations?
    By nano in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-09-2007, 02:53 PM
  4. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
  5. Low Brake Pad Warning & Changing Lower Gear
    By dna_628 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-06-2007, 03:29 PM
