Thread: Electronic handbrake
  1. Electronic handbrake
    Aug 2009
    Chorley UK
    Hi All,
    Just back from 2 weeks holiday last night, my A8 3.0TDI spent it on the driveway, tried to go for a drive this morning and all sorts of warnings came up on the display, it turns out that my electronic handbrake has locked up the rear wheels and the car will not move!!!
    Is this a problem anyone else has had? Any ideas how to overcome this issue?
    Thanks for your help.
  2. Re: Electronic handbrake
    Jan 2009
    towcester northants
    they are s--t
    you can reverse polarity on the motors to release handbrake but its not advisable as if car not chocked then it will run you over
  3. Re: Electronic handbrake
    May 2007
    knee deep in clunge
    14 Post(s)
    Under voltage causes this as battery management cuts in so to over come the park brake remove the two 30 amp fuses located in the osr luggage compartment then refit after 10 seconds then go to park brake with vag com and reset the basic settings which will recalibrate the the callipers,also consider the brakes are locked from sticky pads like normal handbrakes which stick after long periods of engagement,there is no need to reverse the polarity unless the calliper have failed which is highly unlikely and electric park brake is very efficient and failures are very rare.If you have Audi assist support they will come out and resolve the issue
    read the link and follow as per safety instruction but also charge the battery for at least 8 hours or check on the mmi screen user settings the battery display if its not listed add 32 to adpation channel 2 in address 07 then restart the mmi and it will be listed
    http://wiki.ross-tech.com/index.php/...#Basic_Setting
    YOU CAN SOMETIMES OVERCOME THIS BY SIMPLY RECHARGING THE BATTERY OR RUNNING THE ENGINE FOR A WHILE UNTIL THE BATTERY MANAGER STARTS TO SEE CRITICAL VOLTAGES RETURNED AS THE MANAGER TURNS CONSUMERS OFF TO ALLOW CRANKING FOR EXAMPLE KEY LESS ENTRY IS NORMALLY TURNED OFF BY DISABLING THE DOOR HANDLES SWITCHES
  1. Replacing rear pads with electronic handbrake
    By twinturbo in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-07-2009, 11:05 PM
  2. Audi A6 2006 - disable electronic handbrake
    By chodecz in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-06-2009, 08:41 PM
  3. Passat Electronic Handbrake (doomsday scenario)
    By meoman in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-06-2009, 05:52 PM
  4. Electronic Handbrake Activation.
    By DocL in forum Passat - Archive Topics
    Last Post: 16-05-2007, 01:36 PM
  5. Passat Electronic Handbrake Problems
    By wildinthecountry in forum Passat - Archive Topics
    Last Post: 08-10-2006, 05:39 PM
