Thread: Sporadic fault.
  1. Sporadic fault.
    Apr 2007
    Aberdeen
    Hello all. I'm new to this, so bear with me.
    Bought my Leon 1.9 tdi cupra at the **** end of January. Second hand, warranty runs till May, chuffed to bits as I'd been after one for about a year. Anyway, dashboard light comes on - manual says if this light flashes then you've got high emissions. Well the light aint flashing, it’s just on. Got it looked at, 2 hours later was told it was a “sporadic fault” the recommended guidelines were to reset the computer and take it for a test drive. They did this and assured me everything was fine. Drove it home, drove it to work, got in it after work and the light was back on.
    Just wondering if anyone else has had this problem and what it resulted in. The service centre does not fill me with confidence, especially when I said that there must be something wrong with either the sensors or the things they sense and that all of the above should be checked. This was met with a {big sigh} “That’d take ages”
    I've re-written this 3 times due to the scale of my angry ranting.
    '04 SEAT Leon 1.9 TDI Cupra
    Dec 2006
    Manchester
    I'd start with getting the ECU read via VAG-Com or similar...
    That may flag up what sensors are saying what... Most garages do it now, normally for around £40.
    Nick
    Apr 2007
    Aberdeen
    Is VAG COM not what all the VW/Audi/Seat/Skoda garages use for scanning my ECU anyway? It's booked back into Seat garage for Tuesday morning. Will provide update then.
    Canada
    VAG-COM is the 3rd party version of the VAG gealer software. It consider the best for any independant VW garage.
    If you get the emission light then you are probabley looking at a sensor fault. MAF, Lamda/Oxygen Sensor etc. The code reader should give an accurate idea. If your taking it to the dealer ask for the error report and post up here.
    Rob
    7 Post(s)
    The first thing I'd do as it's your car is to ask them what the fault is ??
    If you can find that out, you'll be able to get better advise and re-search it better.
    A fault code or a fault name would suffice.
  1. Abs Fault..... Please Help!!!
    By sels bora in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 16-04-2007, 08:54 AM
  2. T Reg Passat - Electrical Fault, Remote Central Locking Fault
    By adriana in forum Passat - Archive Topics
    Last Post: 01-03-2007, 06:27 PM
  3. EPC fault light
    By batesie1981 in forum Passat - Archive Topics
    Last Post: 20-02-2007, 03:14 PM
  4. ABS Fault
    By mygolfvr6 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 06-07-2006, 07:37 PM
  5. A4 ABS ECU FAULT
    By big phil in forum Archive posts
    Last Post: 13-02-2006, 08:36 PM
