Thread: Water pump failure
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: Water pump failure
    Mar 2007
    Sorry I have no idea what type it was, I got a VW specialist to do it for me.
  2. Re: Water pump failure
    Jul 2008
    Beverley, East Yorkshire
    Quote Originally Posted by mickel2 View Post
    Hi all, i have a 2001 Passat tdi sports estate, i bought the car privately 3 years ago when the vehicle had done 87,526 miles. It had the service history as it was an ex reps car. At 60,000 the cambelt was changed by VW garage.
    At 103,000 the water pump failed without warning as i pulled away from the traffic lights, being a mechanic i regularly check fluid levels and no sign of coolant loss. It was stripped down by a pro engine rebuilder and the pump itself had fallen to bits. This bent all the valves, camfollowers, hydraulic lifters, crankshaft pulley ( damaged by the bearings falling out and going round with the cambelt) The local Scoda was VW agent says the pumps are good for 150,000 plus miles. Would i have any claim against VW, my man is keeping all the parts removed. Mike
    I had my cambelt changed at 112,000 and the Skoda dealer strongly advised that the water pump and the main drive belts were replaced at the same time due to the work involved - he advised me that it was not policy, just good practice. I took his advice as I had a minor water leak and wanted to rule out the pump. They also suggested (upon stripdown) that the alternator tensioner should be replaced as it was worn out - altogether £500!
    Hope you get sorted!
  3. Re: Water pump failure
    134 Post(s)
    2022 Post(s)
    Unless I am allowed to change the pump, I will not even do the job. Typically they are £35 genuine VAG and so not changing it is stupid. No way are they good for 150k miles, the Skoda dealer was completely in the wrong saying that.
  4. Re: Water pump failure
    Jul 2009
    Norfolk UK
    Thanks for the replies. I phoned Audi today and asked if they advise customers to change the pump as well and they said yes. I said they should make it mandatory at the cambelt change for the price of a pump. Audi are doing a special price at the moment for cambelt change approx £340!!!
  5. Re: Water pump failure
    Aug 2008
    Vgood. My recent pump/cambelt was £560 (3.5hrs labour + parts) although it is a V6 unit.
  6. Re: Water pump failure
    134 Post(s)
    2022 Post(s)
    The V6 is much more involved.
  1. A6 (C5) 1.9 PD TDI Oil Change with Pella
    By Col in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-10-2009, 09:43 PM
  2. 1.9 PD TDI Oil Change with Pella
    By Col in forum General
    Last Post: 21-07-2009, 07:56 PM
  3. Water pump moral - AAZ engine
    By the_old_diver in forum Early Passat Forum - Pre 97
    Last Post: 19-07-2009, 11:01 PM
  4. ADR engine - Power steering / water pump belt
    By ANDY-C in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-04-2009, 01:11 PM
  5. "How To" The FAQ & How To Thread
    By Ben in forum General
