Thread: Golf mk4 water in driverside footwell and rear driverside footwell??
  1. Golf mk4 water in driverside footwell and rear driverside footwell??
    Jul 2009
    Swindon Wiltshire
    Hi Guys,
    Ive got a mk4 2000 plate gt tdi golf, recently noticed the carpet is soaking in the drivers footwell and also the rear driverside footwell. Really not sure what this may be so any ideas would be appreciated ?
    cheers guys
  2. Re: Golf mk4 water in driverside footwell and rear driverside footwell??
    135 Post(s)
    2043 Post(s)
    Do you have a sunroof? Do the pedals get wet? Have the door panels been off to repair a fault window winder mechanism?
  3. Re: Golf mk4 water in driverside footwell and rear driverside footwell??
    Jul 2009
    Swindon Wiltshire
    Yes the car does have a sun roof, pedals arnt wet atall water starts from just under the pedals completly covers the area were the car mat sits and also under the seat and rear footwell driverside, door panels havent been off atall. cheers
  4. Re: Golf mk4 water in driverside footwell and rear driverside footwell??
    135 Post(s)
    2043 Post(s)
    Possibly a blocked sunroof front drain (they are in the door shut, use an air line to blow top down only or you get filthy water all over the interior, don’t ask how I know this) or the most likely culprit is the wiring conduit cover under the wiper motor is allowing water in, quite a long job to do and often requiring a new cover.
  5. Re: Golf mk4 water in driverside footwell and rear driverside footwell??
    Jul 2009
    Hampshire
    Hi - I had this problem with my mark 4. It turned out the windsreen washer tube wasn't sealed in place properly at the base of the windscreen near the hinges of the bonnet (sorry -not a very technical desription!). It just needed some sealant to stop rain water running in the gaps and I haven't had any leaks since.
  6. Re: Golf mk4 water in driverside footwell and rear driverside footwell??
    Dec 2010
    Aberdeen Scotland
    I had this problem also. I used a net curtain spring to clear out the sunroof drains, needless to say it didn't come out the drain hole on the drivers side, meaning the tube had somehow disconnected itself. I removed the rubber bung above the wiring gaiter for the door and fished out the spring then applied some WD40 to the bung , slipped the spring through the bung so as to line up the tube and pushed the bung back into position. Pour some water down the sunroof drain to make sure it comes out the drain at the door. Job done no more water.
  1. Water in the rear pasenger footwell?
    By MacG130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-03-2008, 08:54 PM
  2. major water leak problem A4 Drivers side rear footwell soaking wet
    By steve888 in forum Audi A4 - Archive Topics
    Last Post: 17-01-2008, 10:27 AM
  3. Water in rear pass footwell
    By Michelin in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-01-2008, 03:41 PM
  4. Water in rear passenger footwell
    By avantiblue in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-01-2007, 01:43 AM
  5. Golf Mk4 2002 water leak
    By kevrev in forum Golf MK4 - 1999 - 2004
    Last Post: 05-01-2007, 12:08 AM
