Thread: 2.5 tdi oil mist separator part numbers
  1. 2.5 tdi oil mist separator part numbers
    Aug 2007
    Asnières-sur-Blour, Vienne, France
    9 Post(s)
    Hello, I have a 1999 AFB 2.5 tdi A6. I had problems with the oil mist separator and had it changed last year by Audi with the original part number V059 103 464. It seems to have blocked already and I have read in other posts that this part can be replaced by part 059 103 464 B which does not have the gauze filter which I think was the problematical element. Before I read those other posts I went to my local VAG garage in France, described the part I wanted but they have supplied me two packets with different numbers 059 198 067 and 046 198 475 B. Can anyone tell me if these two part numbers make up the revised 059 103 464 B part. It is a bitch to replace and I don't want to take it all to bits and then have to take the parts back and wait 10 days for them to be replaced. Thanks, Michael
  2. Re: 2.5 tdi oil mist separator part numbers
    Jan 2009
    towcester northants
    hello michael i will check these part nos with trade parts centre for you and let you know Pete
  3. Question Re: 2.5 tdi oil mist separator part numbers
    Apr 2009
    Sorry to hijack this thread but these filters are made by Hengst for VAG. If somebody can get me the Hengst part number I may be able to get Euro Car Parts to start stocking them. Should be a lot cheaper than the £50 my local main ******* wants for one!!!
  4. Re: 2.5 tdi oil mist separator part numbers
    Aug 2007
    9 Post(s)
    Hello, Hengst list fuel, air and oil filters for this car but do not offer oil mist separator, when the OE old and new numbers are entered no options are offered. Michael
  5. Re: 2.5 tdi oil mist separator part numbers
    Aug 2007
    9 Post(s)
    Hello, Can now say that the parts ( 059 198 067 and 046 198 475 B)supplied by the VAG garage were incorrect, they were in fact parts that make up the diaphragm unit situated vertically to the left of the oil mist separator When the garage inputs your chassis number into the computer, there is no listing for oil mist separator, the part is listed as set of seals (set des joints in France). If your chassis is listed as up to Y you will be supplied the old style oil mist separator 059 103 464, even though it is a troublesome part, the gauze filter is made of a nylon type fine material but the fibres absorb the oil and in time swell and reduce the ability of the gases to pass through causing high crankcase pressure. The new part 059 103 464 B uses a different filter medium and should be less likely to block, but still fits the old engines. Hope this is of help to some members. Michael
    Quote Originally Posted by mhobson View Post
  1. Please Help Best Golf for £10k and confusion over different engines?
    By deshg in forum Golf MK5 - 2004 - 2009
    Last Post: 21-09-2010, 07:47 PM
  2. A6 2.5 tdi AFB Oil Mist Separator
    By mhobson in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-07-2009, 11:18 PM
  3. 1.9 TDI PD 150 Oils
    By mikebeardmore in forum Golf MK4 - 1999 - 2004
    Last Post: 19-04-2009, 11:36 PM
  4. Answers From The Oil Expert Part 2
    By oilman in forum Archive posts
    Last Post: 22-10-2007, 08:30 AM
  5. Answers From The Oil Expert
    Last Post: 22-10-2007, 08:28 AM
