Thread: Golf Mk4 1.6 Revs Fluctuate / stalls / temp up & down!!
Results 1 to 10 of 12
  1. Question Golf Mk4 1.6 Revs Fluctuate / stalls / temp up & down!!
    Mar 2007
    Oxfordshire
    I've just aquired a 1998 Mk4 Golf 1.6SE off some friends who are clueless about cars. It drives well and has done 103K - but it needs work. The main problem is that the revs fluctuate badly (500 - 1000rpm) when idling and it oftern stalls (when idling). I watched the temperature guage go upto near 90 after a few minutes , then it dropped to 70, then went up again... Are the two problems relatated? Is the temp really going up and down?
    Any help really greatfully recieved - then I can move onto the dodgy door locks, rear wiper and front suspension!
    Mar 2007
    Oxfordshire
    Ok well I'm guessing it's the temperature sensor so I'm going to put a new one in this evening.
    Nov 2006
    Im sorry i gotta break it 2 u like this but mate its sounds bad i had a 1.6S MK 4 golf and it had the same problem....
    Basically the idling and when u come to a halt at a light it stalls is what i incured alot and i got so fed up i ended up changing the car... The part that needs replacing is a THROTTLE BODY best place 2 do that from is VW becuz u will gt guarntee but be warned does cost a bit... the second option u have with that is what i used to do was get the actually Throttle Body Cleaned out becuz muck gets stuck in it and if u use Nail Varnish and clean it out properly u should be able to clock up on average 5000/6000 miles before it goes again..
    The temperature Needle i had that problem on mine as well that is just a sensor fault not actually linked to the Idling problem.
    Hope this helps
    Mar 2007
    Oxfordshire
    Hi, thanks for the reply. I think you are right - I replaced the temp sensor and now it reads the correct temperature...but still stalls! My first stop is to clean the throttle body - then a £300 replacement if all else fails! Bummer.
    Mar 2007
    If only I had found this forum 2years ago.... I had exactly the same situation as yourselves, and ended up doing what Anzee did... sold my 1.6 SE Golf. I had looked after it extremely well, and got fed up having it checked over by many garages who tried and tested different things, but to no avail. The main VW dealers said its not something they've heard off, and would cost £65 per hour to diagnose the problem, and then depending on the fault, cost accordingly to fix. I wouldn't have mind paying £300 for a replacement, as I ended up selling the car for more than £1500 less than its actual value.
    The guy who bought it knew its a bargain!
    Quote Originally Posted by randall977 View Post
    i had a similar fault on my last car (fiat) , with the throttle body, i can't see how replacing it would do more than a good clean is capable of doing... its basically just a cylinder with a butterfly valve in the middle of it, give it a good clean and it should be good as new
    Mar 2007
    Oxfordshire
    Cleaning the throttle body did cure the problem, though I'm not sure using WD40 as the cleaning agent was a good idea? I'm also not sure if I need to reset the fault code??? I disconnected the battery for 10 miutes. The revs are a bit high when idling (1500rpm), why is this?
  1. low revs on cold start -golf mk3 1.8
    By noho in forum Golf MK3 - 1993 - 1999
    Last Post: 20-08-2009, 05:38 PM
  2. a3 starts and stalls
    By dolly in forum Audi A3 - Archive Topics
    Last Post: 05-06-2007, 06:01 PM
  3. Miss-firing at low revs - Golf 1.6 1999
    By joe1703 in forum Archive posts
    Last Post: 04-12-2006, 06:07 PM
  4. Mk3 Golf Engine Stalls
    By JamieLoganUk in forum Golf MK3 - 1993 - 1999
    Last Post: 07-03-2006, 06:47 PM
  5. 1991 80SE Nearly stalls after ignition ?
    By tattersfield in forum 80 - 90
    Last Post: 25-10-2005, 11:19 AM
