Thread: re passat alarm and lights
  1. re passat alarm and lights
    Apr 2009
    kettering
    Hi Can anybody help or advise me i have a 2003 53 passat tdi sport and recently has developed a problem whereas the indicators won't flash when the alarm is armed or de armed, The alarm is working however when the alarm is sounding lights do not flash either, Not bulbs as indicators are fine so are hazzards and all other lights, The carpet is bone dry passenger side even under the underlay.
    Can anybody shed some light or pointers to check, is there a test mode i can put the car in to check the central locking solenoids are not at fault although all doors lock and unlock ford used to have a system where you could put the alarm into test mode and open each door boot and bonnet individually and the alarm would beep once letting you know the circuit was fine the door that diddnt beep Hey presto. Does the passat have the same style of test?????????????? Or can anybody tell me where the wiring or relay for the alarm are so i can get a tester on there Many Thanks Dan.
  2. Re: re passat alarm and lights
    Jan 2009
    towcester northants
    you will need to get a diag machine plugged into the cdl system
    then you can do a final control diag test on the alarm
  1. Please Help Alarm failure on passat 2001 2ltr
    By ST.Alban in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-07-2009, 08:18 PM
  2. Passat Votex Alarm
    By nacoya in forum Passat - Archive Topics
    Last Post: 11-02-2008, 09:10 PM
  3. Audi A4 Alarm
    By raemaruk in forum Archive posts
    Last Post: 14-11-2007, 02:47 PM
  4. PASSAT Alarm and reverse sensor problems
    By Intake in forum Passat - Archive Topics
    Last Post: 26-06-2007, 09:33 PM
  5. POLO Alarm No Siren Jus Flashing Lights
    By dbrooksy in forum Polo - Derby - Lupo - Fox
    Last Post: 07-05-2007, 03:53 PM
