Thread: Alarm Question - what does it need to activate it?
  1. Alarm Question - what does it need to activate it?
    Aug 2007
    Cambridge, Cambridgeshire, United Kingdom
    15 Post(s)
    I ask as my pride-n-joy is outside the front windows at night, parked on the road. Thursday/Friday night last week some bas**rd decided to drive into the front wing on the "exposed" side (which is the passengers side) which is doubly impressive given I was in a row of parked cars so you had to literally swerve into it to hit it (or be backing into a space and clobber it). They've put a highly visible dent in the profile of the wheel arch (and you can feel a kink in the inside of the arch) plus left a dark paint streak and a load of placcy bumper residue.
    Alarm did nothing.
    What does it actually need to set the damn thing off? A war going on on the bonnet?
    Cheers,
    Dan.
  2. Re: Alarm Question - what does it need to activate it?
    Southern County Softy
    20 Post(s)
    Does the alarm work ?
    The siren is vert quiet.
    You can try setting it off yourself, lock the car with a window open then wave your arm about inside the car to set it off.
    A4 2.5 tdi QS (mapped)
  3. Re: Alarm Question - what does it need to activate it?
    Aug 2007
    15 Post(s)
    Quote Originally Posted by kite View Post
    It's not that quiet - and yes it works, doubly so when I leave the dog in the boot and forget to disable the internal sensors....
    I was more alarmed (pun intended) that so far it seems to have done nothing with respect to people meddling from the outside.....
    Cheers,
    Dan.
  4. Re: Alarm Question - what does it need to activate it?
    20 Post(s)
    It does have a tilt sensor.....
    Wonder if the sensor can be adjusted............
  5. Re: Alarm Question - what does it need to activate it?
    Aug 2008
    Somerset
    I wonder if the tilt sensor only works in one plane? In other words, a collision with the front of the car might jolt it but not necessarily in a way that the tilt sensor would recognise. Just a thought.
    The sensor itself is fairly sensitive, though. Mine was set off when a friend sat on my towbar-mounted cycle carrier, causing the rear suspension to settle by an inch or so...
  1. Is Alarm system fitted to the 06 Passat effective?
    By mac500 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-06-2010, 09:54 PM
  2. Please Help Alarm failure on passat 2001 2ltr
    By ST.Alban in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-07-2009, 08:18 PM
  3. Please Help Factory Alarm stopped working
    By avata_jo in forum Golf MK2 - 1984 - 1992
    Last Post: 21-07-2009, 07:01 AM
  4. alarm triggered with driver door
    By Steve-R in forum VCDS - General Questions
    Last Post: 05-05-2008, 07:31 PM
  5. Alarm Question 2002 A4 Avant
    By Gazz in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-01-2007, 01:09 PM
