Thread: Strut removal '90 Driver..
  1. Strut removal '90 Driver..
    Jul 2009
    Brighton UK
    I know this should be obvious, but I've not stripped a Golf before-do the front struts come off as one unit as most cars do, or do the springs need compressing first? I can't tell from the top mounting if it stays attached to the body when the top nut is undone. Same with the rears, one unit then remove the coil spring when it's off the car?
    TIA guys, if it was a BMW I'd be able to tell you what to do!
  2. Re: Strut removal '90 Driver..
    Jan 2009
    towcester northants
    strut comes off from top of the hub
    mark up as this is camber adjustment
    the top mount stays with the strut and you compress when off
    they have a special tool for the removal of the top mount
  3. Re: Strut removal '90 Driver..
    Jul 2009
    Brighton UK
    Cheers for that!
  1. Replies: 21
    Last Post: 16-07-2015, 03:07 PM
  2. Mk2 GTi front strut removal ?
    By Dan2880 in forum Golf MK2 - 1984 - 1992
    Last Post: 24-07-2009, 01:01 PM
  3. Replies: 0
    Last Post: 28-04-2007, 03:27 PM
  4. STATESIDE DEBUT FOR AUDI ROADJET CONCEPT
    Last Post: 15-01-2006, 03:36 PM
