Hello folks
New member here with a poser of a problem for you, Any help would be appreciated.
Car is a 1998 20V 1.8 Sport Turbo (Passat) unmodified
Using VAG.com through the USB and OBDII cable from ebay.
VAg.com runs OK and can talk to the Comfort system, dash, climatronic and autogear box. Can clear faults and everything on theses controllers
However, it will not connect to the engine or the ABS, Tried everything
even checked the K line connection to these units.
Now getting really annoyed. Anyone had similar problems.
