Thread: Oil filter location
  1. Oil filter location
    Apr 2007
    I was hoping to service my B6 Passat 2.0 tdi, can someone please tell me where the oil filter is???
    May 2007
    if you lift the top cover off the engine at the front look stright down and just right of the pipes coming up for the inlet manifold there's a black cap with a nut on top unscrew this and there's a paper filament type oil filter there when replacing it also replace the black rubber "o" ring that is on the cap of the oil filter and and when refitting put some oil on this "o" ring also put some oil the the small "o" ring at the bottom of the new filter
    Apr 2007
    France
    12 Post(s)
    Quote Originally Posted by gteyes View Post
    if you lift the top cover off the engine at the front ...............
    Does that just pull off?
    dfb - make sure you use the correct oil, VW will void your guarantee if you don't and there's a problem!
    May 2007
    17 Post(s)
    Quote Originally Posted by Quatrelle View Post
    Does that just pull off?!
    Yes, it does.
    What, the Castrol long life stuff? That stuff is so expensive that some of the VW dealers don't even use it.
    If the cars set up for long life servicing, you'll have to go to the dealer to get the service light reset. Unless you have VAGCOM, of course.
  1. location location?
    By ali-mk3 golf in forum Chat - Completely Off Topic
    Last Post: 08-08-2007, 08:58 PM
  2. Pollen filter location
    By deebee in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 17-06-2007, 07:34 PM
  3. MAF location
    By Toxic VW in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 11-06-2007, 11:02 PM
  4. Mk 4 Polo Polum filter location...
    By Pegasus in forum Polo - Derby - Lupo - Fox
    Last Post: 01-01-2007, 05:38 PM
  5. location location location
    By Shak in forum Passat - Archive Topics
    Last Post: 15-08-2006, 07:54 PM
