Thread: 1.6 Petrol Starting / Revving
  1. 1.6 Petrol Starting / Revving
    Aug 2007
    A friends 1.6 Petrol will sometimes not start for one or two tries. On other occasions it will start but runs at low revs and stops. Usually it will start 3rd or 4th attempt but revs to 3000rpm for second before returning to normal idle and then driving normally. There are no dashlights but there is a beeping sound when the ignition is turned on.
    Have not had a chance to scan it yet but has anyone had any similar issues and can point to the cause perhaps ?
    Ian
  2. Re: 1.6 Petrol Starting / Revving
    131 Post(s)
    1976 Post(s)
    One of many AKL engine issues, start with a fault code read.
  3. Re: 1.6 Petrol Starting / Revving
    Jun 2009
    Bristol, UK
    Had the same problem, I had to clean my MAF sensor and throttle body with injector cleaner, and all if pristine now
  4. Re: 1.6 Petrol Starting / Revving
    Aug 2007
    Tks ama3654 I'll suggest that totry and as vagcom did not throw up any errors at all.
    Engine code is I think ! BCB too it is an 02 plate Golf Mk4 S 1.6.
  5. Re: 1.6 Petrol Starting / Revving
    131 Post(s)
    1976 Post(s)
    You will have fun trying to clean the AMM (MAF) on a BCB, they don’t have one…
  1. Intermittent starting problem
    By Manchester_Golf in forum Golf MK4 - 1999 - 2004
    Last Post: 10-07-2009, 06:12 PM
  2. cambelt interval for 2001 1.6 petrol
    By kevandalice in forum Audi A3 - Archive Topics
    Last Post: 02-06-2008, 05:05 PM
  3. Starting problem on 1800 petrol 1996 Passat estate
    By edmunds in forum Early Passat Forum - Pre 97
    Last Post: 14-05-2008, 09:01 AM
  4. Passat wont start!
    By jasear in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-02-2008, 01:15 PM
  5. gold 1.6 starting problem
    By JohnCunningham in forum Golf MK4 - 1999 - 2004
    Last Post: 23-12-2007, 10:16 AM
